ᐅ Flooring for a Double Garage – Screed with Two-Component Coating? Epoxy Resin
Created on: 18 Oct 2019 18:25
KeviniusHello,
I am considering having fiber-reinforced screed with a slope installed in the garage. On top of that, a two-component epoxy resin coating—that would actually be my ideal solution.
What are your experiences with epoxy resin coatings? How durable are they?
How does the material hold up if a tool or part is dropped on it? Can it be repaired easily?
We have a raw concrete slab that is 15cm (6 inches) thick.
The area is approximately 70m² (750 square feet).
Regards
Regards
Michlhausbauaa19 Oct 2019 16:18Bookstar schrieb:
You can forget it, it won’t last permanently. Get a professional coating done, with 5 work steps, 2 to 3cm (around 1 inch) thick. It lasts 100 years. You can then skip the screed; a concrete floor is enough. What exactly is that?
