I want to integrate a doorbell/intercom system with my FritzBox.
I would like the FritzFon c4 to ring with a different ringtone when the doorbell rings (I do not need video). Is it also possible to open the door using the c4?
Can someone recommend a doorbell/intercom system with a good price/performance ratio? Is my plan feasible?
Thank you
Thank you
I can’t answer this with a definite yes or no because we only use the Fritzfon here. However, it is often mentioned that only the Fritzfon guarantees 100% compatibility with the box. This is not always the case with DECT devices from other manufacturers.
I’m bringing this up again because I need some planning advice on this topic.
In my case, it’s about a three-family house. Of the three doorbells/intercoms with door opener, one should be connected to a FritzBox on the first floor. That’s no problem. However, the doorbells/intercoms with door opener on the ground floor and the second floor should be connected to a different FritzBox. This second box is a 7390. Is it possible to operate two doorbells separately with this box? I have already looked on the Auerswald site, but the descriptions of the modules were somewhat insufficient. Is there a module that can manage this? If yes, which one? Or do you need three separate modules for this?
Thanks in advance!
Thanks in advance!
