ᐅ Door gap Controlled mechanical ventilation Ventilation gap for air exchange
Created on: 21 Dec 2014 16:24
PhoenixDH
I understand that controlled residential ventilation systems require ventilation gaps for air exchange, which makes sense. We have two glass doors, and it is clear that maintaining the required gap height is not possible; the door will be as tall as possible.
We have a list with the specified dimensions outlining the requirements.
What are your thoughts on the assumption that a gap is present but does not always meet the required height? For some doors, a gap of 1.4 cm (0.55 inches) is required, which is quite a significant height.
PhoenixDH21 Dec 2014 20:24These kinds of stories are always taken very literally.
From a purely visual perspective, at least for me, that is the case.
That’s why I’m also asking for reasons why it’s so important to strictly follow the height measurements.
What could happen...
Or if it might not make any difference at all...
nordanney21 Dec 2014 21:10Our heights are approximate. However, since all doors are left open during the day, it doesn’t really matter. At night, we hardly notice any drafts at the door gaps, which are about 6–9mm (0.25–0.35 inches) depending on the door.
PhoenixDH21 Dec 2014 21:37Ok, thanks, that’s a clear statement.
Before installation, we routed the door frames on both sides about 10mm (0.4 inches) wide in the non-visible area at the top, allowing air to flow there in addition to the few millimeters under the door. This is not visible, ensures air transfer, and makes it more difficult for sound to pass through because it has to navigate the "labyrinth" created by the frame and door lintel.
PhoenixDH21 Dec 2014 22:18We didn’t shoot foam and fully insulate the doors either.
So air can flow through there as well.
I’ll see how I’ll handle that.
@One00: About how wide is the gap under your doors?
