ᐅ Door for technical room housing geothermal system and solar energy storage
Created on: 30 Mar 2023 14:30
darksundarksun schrieb:
I can’t find any information about a “boiler room” where a heat pump with a photovoltaic battery system is installed.
Is a fire-rated door required here (Hessen) or just recommended?
The technical room is in the basement,
Thanks! Hello,
Our new build is located in Hessen. We have exactly the same door in front of the technical room (in the basement) as for all the other doors in the house.
Well, the incidents with the Senec batteries catching fire really make you think, I can understand that.
Just install a fire-rated door in front of it. It costs more, but if it helps you sleep better at night, it’s worth it.
Or simply install a safer battery storage system right away (LiFePO).
