ᐅ Does the electrical system need to be updated? (Condominium, 1960s)
Created on: 20 Feb 2024 09:34
TorstenKandt
I am considering buying a condominium. The apartment building (about 20-30 units) was built in the 1960s. I’m wondering if it would be advisable to upgrade the electrical system. Unfortunately, the owners don’t know anything about its current condition. I’m attaching photos of the fuse box and an outlet.
What is your opinion? Should the electrical system be replaced, or is it not necessary? We plan to renovate anyway.
Torsten
Old fuse box with rotary knob, multiple fuses, and dusty casing.
White double socket panel with dirty contacts; dust and a loose part nearby.
hanse987
20 Feb 2024 19:35
If you are already installing cables, make sure to also consider the network wiring.
TorstenKandt
22 Feb 2024 08:27
Thank you for the advice. I will probably include the electrical upgrade in the plans. It shouldn’t be too expensive.
Winniefred22 Feb 2024 08:50
This is not exactly a small item. Definitely five-figure. However, it varies greatly depending on the requirements.
Z
Zubi123
22 Feb 2024 10:14
Winniefred schrieb:
That’s not exactly a small expense. Definitely five figures.
For a new sub-distribution board and a few new cables plus sockets?!
How do you arrive at such a high amount?
TorstenKandt
22 Feb 2024 10:19
Winniefred schrieb:
That’s not exactly a small amount. Definitely five figures. However, it varies a lot depending on the requirements.
Really? I would have expected it to be well under 10,000 euros.
Malle Zwabber22 Feb 2024 10:32
It gets tight under €10,000. By doing some of the work yourself, like cutting the channels and later finishing them, you can definitely save some money. It really depends on your level of carpentry skills. The material itself is not the main cost factor here.
