I recently set up a KALLAX shelf in my basement to store some boxes and tools. However, I noticed that it seems to collect dust faster compared to other furniture in the house. My question is: does the KALLAX gather dust more quickly in the basement than similar shelves in living areas or other rooms?
I’m not only referring to the usual amount of dust but also whether the material or the specific surface texture of the KALLAX in a basement environment (with relatively higher humidity and less air circulation) attracts or retains dust more.
I’m interested both in experiences from people who use this shelf in a similar setting and in explanations about how dust accumulation generally behaves in basements, and whether the KALLAX might be particularly prone to it.
Thanks in advance for your insights!
Hi Ariano,
I think basements are dust magnets par excellence – it’s really not the KALLAX’s fault 😄.
But jokes aside: dust is made up of various fibers, skin flakes, pollen, and so on, and in a basement where the air is often a bit drier and less circulated, it tends to settle faster.
Since the KALLAX shelf is made of MDF-like material with a laminated surface, it shouldn’t attract more dust than other shelves. So it’s more likely a question of how well you ventilate the basement or how often you clean it. With a microfiber cloth, you can easily remove the dust.
If the basement is very damp, however, there could be a problem with mold – that should be monitored. But dust itself: yes, it settles faster in basements, but certainly not because of the KALLAX. 😉
Hello Ariano,
I would like to add something, as this is often misunderstood. Dust accumulation mainly depends on air circulation, indoor humidity, and the sources that produce dust (e.g., textiles, clothing, old cardboard boxes).
Regarding your point about whether the KALLAX in the basement collects dust faster than other furniture: Aside from the fact that, as botibo already mentioned, the material does not have significantly dust-attracting properties, the surface of the furniture obviously influences how well dust sticks.
Smoother surfaces collect less dust, while rougher or porous surfaces collect more. Since the surfaces of the KALLAX are relatively smooth and laminated, it should actually be easier to clean than untreated wooden shelves.
In the basement itself, the dust source is usually greater: because the air circulates less, more fine dust settles. Additionally, higher pollutant concentrations can come from basement areas where building materials are stored, for example.
My advice: regular ventilation and occasional wiping are the most important. If dust bothers you, you could ventilate the basement a bit more often or even consider an air purifier.
Hope this helps!
Hope this helps!
botibo schrieb:
If the basement is very damp, it could rather be a mold problem – this should be monitored.This is an important point. Dust accumulation in basements can be promoted by moisture and poor air circulation. At the same time, this combination mainly increases the risk of mold.
To the main point:
The KALLAX is made of an MDF board with a melamine coating. This surface is smooth but attracts a minimal amount of dust due to static electricity, especially in dry air.
Basement rooms often have higher humidity levels, which reduce static electricity and tend to make dust settle less loosely. On the other hand, dust particles can remain longer due to reduced air movement, which can give the impression that dust "settles faster."
Compared to untreated wooden surfaces in living areas, KALLAX is therefore not significantly more prone to dust. The critical factors are rather the environmental conditions and cleaning frequency.
Recommendation: Improve ventilation conditions and regularly vacuum or wipe the surfaces.
Renla47 schrieb:
Smoother surfaces collect less dust, while rougher or porous surfaces collect more.I agree with this.
Just a quick addition: Dust mainly comes from everyday sources and spreads through the air. If basement rooms are visited less often and ventilated less, dust simply accumulates in areas with little air circulation – for example, on surfaces of shelves like the KALLAX.
If you have the KALLAX in the basement and store boxes there, the boxes themselves may also shed dust or fibers. This can make it seem like the dust settles faster.
My recommendation:
- Regular ventilation, including in the basement if possible
- Dusting with a damp cloth or microfiber cloth
- If possible, store boxes in plastic bags or containers to minimize dust from outside
This way, you can manage the problem quite effectively.
