ᐅ Does IKEA Besta become unstable when storing many heavy appliances?
Created on: 13 Mar 2023 08:34
AmanmarHello everyone,
I am currently planning to outfit my IKEA Besta shelving unit to hold many heavy devices such as hi-fi systems, amplifiers, and some larger electronic equipment. I am wondering: Will the IKEA Besta shelving unit become unstable if it is fully loaded with many heavy devices due to the weight and resulting stress?
I am particularly interested in whether the construction of the Besta system, its anchoring, and the material thickness allow it to remain stable under higher loads over a long period. Are there any known weak points to watch out for?
Thanks for your assessments and experiences!
Amanmar schrieb:
I am mainly interested in whether the construction of the Besta system, its anchoring, and the material thickness allow it to remain stable under higher loads over an extended period.The Besta shelf is basically well designed, but the maximum load capacity per shelf is usually around 20 kg (44 lbs). If you place many heavy items, especially exceeding this limit, the shelves may sag over time and the fastenings may experience increased stress.
It is important to anchor the shelving units to the wall; otherwise, there is a higher risk of tipping. Using additional support strips or reinforcements is also recommended if you plan to carry heavier loads.
To ensure the Besta shelf remains stable under heavier loads, here is a brief guide:
- Do not extend the shelves more than 60 cm (24 inches) in length (according to product specifications).
- Adhere to the maximum weight per shelf, usually around 20 kg (44 lbs).
- Distribute weight evenly to avoid localized overloading.
- Always secure the unit to the wall using the supplied anchors and screws.
- For heavy appliances, consider adding metal reinforcements or extra boards.
- Regularly check that all screws are still tight.
Following these steps will provide a solid foundation for long-term stability.
Gino38 schrieb:
It is important to anchor the shelving units to the wall, as otherwise the risk of tipping over increases.Thanks for the advice! Anchoring to the wall is definitely planned on my end.
I am also interested in whether there can be long-term material fatigue if the shelving is consistently heavily loaded. Are there any reports of deformations specifically with IKEA Besta under heavier loads?
Furthermore, I wonder if the connection between the individual modules affects the overall stability—meaning when multiple Besta units are combined.
From a technical perspective, it can be noted that IKEA Besta shelves are made from MDF panels with a laminated surface. These materials are generally not designed to withstand very high point loads.
Over time, consistently heavy weight can lead to sagging and material fatigue. Connecting multiple modules does increase surface resistance, but it does not replace the need for additional reinforcement.
Wall anchoring remains essential. However, if the load limits are exceeded, only extra reinforcements such as metal brackets or stronger shelves made from wooden panels can help.
