ᐅ Does anyone know of a painted back panel that fits the KALLAX?
Created on: 7 Sep 2024 18:04
Benitatu
Benitatu
7 Sep 2024 18:04
I am looking for a painted back panel that fits perfectly with the IKEA KALLAX shelving unit. Specifically, I need a back panel that is not only visually appealing but also sturdy enough to reinforce the structure slightly. The back panel should have precise dimensions for the KALLAX 4x4 so that it fits flush without gaps that could let dust or small items through.
Perhaps someone here has experience with painted back panels or knows of compatible third-party accessories that you would recommend? Quality and surface finish are especially important to me, and I would also appreciate advice on material choices or possible repainting.
Thanks in advance for your help!
Palenar
7 Sep 2024 20:17
Hello Benitatu,
your inquiry about a painted back panel for the KALLAX shelf is interesting, as the standard model from IKEA usually has only a thin particleboard backing that is not painted and can deform quickly. If stability and appearance are the main concerns, it is important to carefully consider which material is suitable.
For example, painted MDF boards provide a very smooth surface and can be cut to size. I would recommend measuring the exact interior dimensions of the KALLAX before purchasing, because the back panel should be slightly smaller than the overall frame dimensions so it can be inserted and replaced if needed.
A potential issue with painted back panels is moisture resistance, since some paints are not 100% waterproof. If the back panel will be visible, you might consider using polyurethane (PU) paints or even epoxy resin coatings, which are very durable.
Alternatively, some furniture retailers or online shops offer ready-made painted back panels made of wood or HDF (High Density Fibreboard) as accessories, but the quality of these can vary greatly.
Therefore, my question: Do you want to fix the back panel permanently or just place it in? And do you have a specific color choice or requirement? This will strongly influence the product selection.
Benitatu
8 Sep 2024 08:12
Palenar schrieb:
So my question: Do you want to fix the back panel permanently or just place it in? And do you have a specific color preference or requirement? This has a big impact on the product choice.
Thanks for asking! The back panel should be fixed firmly – I plan to attach it to the frame using screws or small clips to prevent it from wobbling or falling out. In terms of color, a matte white or subtle grey would be ideal to blend harmoniously into the living room.
Glossy lacquered surfaces are not my goal, as they tend to show fingerprints. Matte finishes with a smooth feel would be perfect.
Stability is important to me, especially since the shelf might later hold some heavier books or electronics. If you have any experience with exact dimensions for KALLAX 4x4 units with painted back panels, I’d appreciate your input!
Lorukeo
8 Sep 2024 15:29
Benitatu schrieb:
A matte white shade or a subtle gray would be ideal to blend harmoniously into the living room.
Regarding color choice: For matte finishes on MDF or HDF, a water-based acrylic paint is generally recommended. It has low odor, is environmentally friendly, and is available in various matte shades – including RAL colors if precise matching is required.
Concerning fixing: Screwing directly into MDF can cause cracking over time, especially under frequent load. Attaching with small clips or edge strips is often more stable and allows for easy removal if needed.
The dimensions of a KALLAX 4x4 are usually about 147x147 cm (58x58 inches) on the outside, but the back panel should be slightly smaller, about 1–2 mm (0.04–0.08 inches) less in height and width for a proper fit.
I recommend using a back panel with a thickness of at least 4 mm (0.16 inches) if making it yourself, to ensure enough stability and prevent warping.
If you like, I can also provide sources where you can find high-quality MDF trims and paints.
likuken
8 Sep 2024 17:46
I think the discussion is missing the point of whether the appearance of a painted back panel is really worth the extra effort.
Benitatu schrieb:
The back panel should, of course, have exact dimensions for the KALLAX 4x4 so that it fits flush without gaps
But honestly: the KALLAX back panel is usually not visible anyway, because the shelf is typically placed against a wall or next to other furniture. Is this effort really justified?
If someone cares that much about the look, they might as well choose a better shelving system where the back panel is an integral and higher-quality part.
Of course, this is a provocative statement, but I believe most users underestimate the effort behind such painting work – and the time it takes. A simple covering or a very thin panel is usually sufficient if it's just about appearance.
What do you think?
PeoDaniel
9 Sep 2024 09:03
That’s a good point, but there are definitely cases where the back panel remains visible, for example with freestanding KALLAX shelving units or when access to the shelves is possible from both sides.
Additionally, a sturdy, painted back panel can reinforce the shelving unit and significantly extend its lifespan. This can be especially important for heavier contents like books or electronics such as speakers or consoles.
I would recommend weighing the options depending on the intended use: If the shelving unit is placed against a wall and the back panel is not visible, a simple particleboard panel will usually suffice. However, if the shelving unit serves a design purpose, investing in a painted, more stable back panel is definitely worthwhile.
Benitatu, is your shelving unit freestanding or will it be placed directly against a wall?
