ᐅ Has anyone had experience using the Ikea Brimnes furniture in a children's room?
Created on: 26 Nov 2024 09:37
Son31
Son31
26 Nov 2024 09:37
Hello everyone, I am considering using the Ikea Brimnes furniture system for my daughter’s bedroom. Has anyone had experience with this system, especially regarding everyday usability, storage space, and quality? I am interested in how sturdy the furniture is, whether the drawers work well, and if the design is suitable for a child’s room – also in terms of safety and flexibility, as we plan to rearrange the room frequently. Are there any pitfalls or important tips I should be aware of before buying? I look forward to your feedback!
Jensson
26 Nov 2024 11:05
Hello Son31, based on my experience with the Brimnes system, I can offer some helpful insights.
First: The drawers are indeed very spacious and often close smoothly, which is not always a given with many children's room furniture pieces. A tip: Be careful not to overload the drawers, as this can affect the mechanism and lead to problems over time.
Second: The material is MDF with a foil coating, which is acceptable for the price, but the surface can be damaged by rough handling or moisture. For a children's room, this means that small accidents (like spilled liquids) should be cleaned up quickly to prevent swelling at the edges.
Third: The design is simple and purely functional, which suits many, especially when combined with colorful accessories. There are no major safety issues, but you should definitely anchor the cabinets to the wall, as they are relatively tall and could tip over if children climb on them.
In summary: Brimnes is a good, budget-friendly system that offers plenty of storage but requires some care to keep it looking good over time.
neoren
26 Nov 2024 12:44
Brimnes is solid, especially for the price. Just don’t overload the drawers and secure it to the wall, then there won’t be any problems. The surface is not water-resistant, so you need to avoid that.
Domau0
27 Nov 2024 08:19
Jensson schrieb:
The material is MDF with a foil coating, which is reasonable for the price, but the surface can be damaged with very rough handling or moisture.
This is an important point that I’d like to expand on, especially when it comes to furniture for children’s rooms, where choosing the right material is crucial. While MDF is affordable and easy to work with, it tends to be vulnerable to mechanical stress such as impacts or scratches from toys. Moisture can cause the edges to swell in the worst case, quickly leading to unsightly chipping.
From a technical perspective, I recommend paying close attention to the screws and dowels during assembly, since the Brimnes system uses comparatively thin panels. A common but often overlooked issue is the excessive friction of the drawers, which can be worsened by assembly errors or uneven flooring, placing strain on the drawer runners.
Also, I’m curious about the exact room size and existing furnishings in your space. The Brimnes series has a rather straightforward design and isn’t as flexible as modular systems, so it would be helpful to know if you have specific space requirements or if you plan to combine the furniture with other pieces. Could you briefly explain this? That would assist with advising you.
nubar
27 Nov 2024 15:52
I would like to add that the Brimnes series, with its straightforward design and proven construction, offers a solid storage solution for many families. In my opinion, besides securing the furniture to the wall, it is also important to organize the drawer compartments not only by volume but also by weight to reduce the strain on the drawer slides.
Additionally, it is advisable to regularly check the surface and promptly repair small scratches or wear using appropriate wood repair kits, as otherwise the overall appearance can quickly deteriorate. For a well-maintained look over time, I would also recommend avoiding placing the furniture directly next to heavily used play areas to prevent unwanted damage.
All in all, I consider Brimnes a functional choice that can be well integrated into a structured room design.
