ᐅ Do you turn off the heating completely while on vacation?
Created on: 30 Aug 2017 21:42
raffa
Hi,
a quick question. What do you usually do when you are away on a longer vacation? Do you turn off the heating completely? I’m mainly asking in terms of hot water supply. At this time of year, the heating is usually off anyway. But the hot water system keeps running, whether it’s powered by a heat pump, gas, or solely solar. The pumps keep running, which seems pointless when no one is home. And heating water for nobody... I don’t see the reason.
So my question is: what do you do when you go on vacation?
Nordlys
31 Aug 2017 12:12
Yes. Cats love to take showers. They are real water enthusiasts. Especially when you shampoo them, they squeal with delight......K.
raffa
31 Aug 2017 12:28
Knallkörper schrieb:
Does the cat need warm water for showering?
How cool! 😀
Steffen80
31 Aug 2017 12:45
Legionella prevention is actually a good point. I basically can’t turn off the heating system, right? What happens if the water in the buffer tank sits for 3 weeks?
Caspar2020
31 Aug 2017 13:14
Steffen80 schrieb:
Legionella function is a good point. So I actually can’t turn off the heating, right? What happens if the water in the buffer tank stands for 3 weeks… then?
If you have a proper heating system, it would heat the water at least once a week during vacation...
raffa
31 Aug 2017 13:17
And if not, you just come back after 3 weeks and manually start the hot water production.
With ours, this is done by pressing a button. Then I heat the water to over 60°C (140°F) and that’s it.
Why run the weekly anti-legionella program if you’re not around anyway? I think it doesn’t really matter if the water in the buffer tank stands for 1 or several weeks, since heating to 60°C (140°F) kills everything regardless of how long the "soup" has been sitting.
Alex85
31 Aug 2017 13:49
If you look at it that way, the discussion is actually irrelevant because maintaining that small amount of hot water at temperature for a week won’t break the bank. Storage losses are said to be around 1-2 kWh per day, which translates to about 10 cents per day.
Like I said, it’s just laziness.
