ᐅ Would you recommend liquid textured wallpaper (paintable wallpaper)?
Created on: 16 Jun 2017 18:46
Hagiman2000
Hagiman2000
16 Jun 2017 18:46
I have read about liquid woodchip wallpaper several times now. It can simply be applied with a roller. I think it would work well for the ceiling in our new build. Does anyone here have experience with this from the forum?
Aotearoa
16 Jun 2017 19:01
I saw it at a friend’s place, where they used this paint above the tiles in the bathroom.
The most important thing they told me was to stir it well so that the particles mix evenly.
I can’t say anything about the application, as their father did that.
Mycraft16 Jun 2017 19:23
I can’t recommend it... if you want to have something different on the wall, be prepared to spend about a week per room to get that material off the walls...
Nordlys
16 Jun 2017 21:22
What’s the savings? Primer is necessary anyway. The walls need to be skim coated as well. Just apply dispersion paint straight on, or stick on a textured wallpaper and paint over that. Karsten
Gartenfreund
18 Jun 2017 06:20
I have often read that people apply paint directly onto the wall. I wonder why this is done— to save money? However, this could backfire. As mentioned before, removing the paint later could be quite a lengthy process, and in extreme cases, the wall might even need to be replastered.
Therefore, I would also suggest first applying woodchip or scrap wallpaper to the wall and then painting over it.
nelly190
18 Jun 2017 11:38
I have worked with this material before in a 14m² (150 sq ft) room. I can say it is quite messy, and you need to apply two coats before it looks acceptable. I would not recommend using it.
