ᐅ Do you have any tips for retrofitting soft-close systems in IKEA PLATSA units?
Created on: 15 Mar 2015 07:38
Ansugo
Ansugo
15 Mar 2015 07:38
Hello everyone, I am currently considering how to retrofit my existing IKEA Platsa furniture with a soft-close system, as the doors and drawers currently close quite loudly and abruptly without any damping. Has anyone had experience retrofitting soft-close systems on PLATSA? I am especially interested in recommendations for compatible retrofit kits, the installation effort—particularly regarding possible adjustments to the hinges or drawer slides—as well as tips on positioning the dampers so that the system works reliably and the furniture is not damaged. Are there common mistakes to avoid? Thanks in advance for your advice and experiences!
FAZAR
15 Mar 2015 10:22
Ansugo schrieb:
Has anyone here already had experience retrofitting soft-close systems on PLATSA?
In general, retrofitting soft-close functions on IKEA PLATSA is definitely possible, but it depends on the specific type of door and drawer slides. The PLATSA series mostly uses simple hinges without integrated dampers and relatively narrow side panels on the units, which can sometimes make installing external dampers more challenging.
I recommend the following approach:
- Identify the type of hinge: If they are classic barrel or flap hinges, soft-close adapters can usually be clamped onto or screwed into the hinge mechanism.
- For drawers, retrofit kits with dampers and spring mechanisms are often suitable; these can be attached to the metal sides of the drawer slides.
- Before installation, be sure to check the measurements carefully, as some soft-close modules require more space, and PLATSA units can have limited installation depth.
A common mistake is positioning the dampers incorrectly, so that the door brakes either too early or too late, causing noise or poor function. Therefore, installation should be as precise as possible following the assembly instructions. Also, check the load capacity of the retrofit systems—doors with heavy use may cause standard kits to wear out quickly.
Regarding the drawers again: Some retrofit kits require that the drawer slide itself has a certain minimum side width, otherwise classic small soft-close units cannot be used.
One more question: Are your PLATSA modules currently fitted with the standard hinges, or have you possibly used alternative hinges or slides from IKEA? This can affect which solutions are suitable.
blaje2
15 Mar 2015 11:47
I upgraded my PLATSA drawers with standard soft-close kits from IKEA designed for metal runners. Simply pull out, clip the dampers onto the back, and you’re done. For the doors, I used IKEA’s soft-close hinges directly – it’s worth removing the doors and replacing the hinges completely.
Guyju
16 Mar 2015 08:11
That is absolutely right and can be avoided by working step by step. I have put together a small guide for retrofitting soft-close systems on PLATSA that might help you:
- Preparation: Check exactly which hinges and drawer slides you have. PLATSA uses simple pivot hinges that are compatible with IKEA soft-close inserts.
- Replacing door hinges: Purchase the appropriate soft-close hinges from IKEA, remove the old hinges, and install the new ones. Make sure to tighten all screws firmly without damaging the wood.
- For drawers: There are two options depending on the type of slides:
- If you have full-extension metal slides, you can install soft-close dampers that simply clip into the rails. Pay attention to the correct orientation.
- If you have plastic guide rails, it might be more difficult, and you may need to replace the slides.
- Test closing: Test everything multiple times and adjust the hinges if necessary—many PLATSA parts allow fine adjustment in three dimensions.
It is also important, after the modification, not to apply heavy loads directly into the fully opened drawer. This helps protect the dampers from excessive wear.
If you can specify more precisely which PLATSA version you have and what kind of drawers or doors you are working with, I can provide you with more specific advice.
