ᐅ Do you have any tips for maintaining the plastic components of IKEA PLATSA units?
Created on: 17 Nov 2020 10:22
tibujar46
I recently purchased an IKEA PLATSA system and am currently taking care of the plastic components on the frame and doors. Since these parts are made of plastic, I’m wondering which cleaning and maintenance products are suitable without making the material dull or causing it to degrade.
Does anyone have tips on how to best clean and maintain the plastic surfaces to prevent both dirt buildup and microscopic scratches? Are there any products that should definitely be avoided because they can damage the plastic?
I’m also interested in experiences with long-term care, as the material can wear out quickly with frequent use.
I look forward to your practical recommendations and advice on how to treat the plastic parts of IKEA PLATSA!
pakokla
18 Nov 2020 09:50
I clean and maintain only as needed, no more. If it is visibly dirty, I use soap; otherwise, I just wipe it dry. I avoid using any maintenance products.
ladali
18 Nov 2020 11:12
Regarding long-term care for plastic parts from Platsa, I would like to add the following:
Polypropylene and ABS are durable plastics, but they are sensitive to UV radiation and certain chemicals. Indoors, UV exposure is hardly a factor, but aggressive cleaning agents can promote microscopic cracks.
A professional way to preserve the surfaces is to use a mild plastic conditioner that removes residual moisture while forming a thin, breathable protective layer. When applied correctly, this layer should not become sticky or attract dust.
It is important that no residue remains after application; therefore, excess product should be wiped off with a clean cloth after it has been absorbed.
Ultimately, regular but not excessive maintenance can make the plastic more resistant to mechanical stress. For household use, however, it is usually sufficient to rely on mild cleaners and soft cloths.
sonpar
18 Nov 2020 13:33
Maintenance works for me like this: warm water with some dish soap, then wipe dry. I don’t use any care products, haven’t noticed any benefits.
stefangla
19 Nov 2020 08:05
theo63 schrieb:
I am a bit skeptical; cleaning recommendations without a specific material analysis are rather general.
That is a very valid point. Ideally, materials should be clearly defined. However, since IKEA rarely publishes detailed material data sheets for such furniture parts, personal tests or experiences are helpful.
tibujar46 schrieb:
Has anyone had experience using plastic care products on furniture parts, specifically how often they should be applied so the surface does not become too "sticky" or attract more dust?
My recommendation: use such care products sparingly and infrequently, for example every 6 to 12 months is usually sufficient. Often, regular cleaning alone is enough. Avoid products containing strong oils or paraffins, as they can attract dust.
It is also important to always test the product on an inconspicuous area first to see how the plastic reacts before applying it extensively.
