ᐅ Do you have any tips for maintaining the surfaces of Ikea HEMNES furniture?
Created on: 29 Sep 2024 13:07
Ligi30
Ligi30
29 Sep 2024 13:07
I recently bought some furniture from the Ikea Hemnes series, mainly dressers and tables with the typical finishes, which are mostly lacquered wood or MDF. Since I generally care about maintaining the surfaces as beautifully and durably as possible while avoiding harmful cleaning products, I would be very interested to hear: Do you have any practical tips for caring for Ikea HEMNES surfaces to prevent or repair scratches, dull spots, or damaged areas? Which cleaning products or methods have proven effective, and are there any special precautions to keep in mind during daily cleaning? I would like to know how to keep the furniture looking as close to new as possible over the long term.
Thank you in advance for your advice!
Palenar
29 Sep 2024 14:41
Hello Ligi30,
to provide a comprehensive answer to your question about caring for Ikea HEMNES surfaces, I would like to explain a few details and recommended practices. The HEMNES series is known for its matte, lacquered surfaces on wood or MDF with real wood veneer – this means the surface is more sensitive than, for example, high-gloss finishes and reacts more easily to improper care.
- Cleaning:
- Avoid using harsh or abrasive cleaners that could damage the lacquer. A soft, damp cloth is usually sufficient.
- Ideally, clean your furniture with a mild, pH-neutral soapy water, applied with a well-wrung cloth. Avoid leaving surfaces wet or dripping.
- Avoid aggressive chemicals or alcohol, as they can dull the protective layer over time.
- Protection and maintenance:
- Direct sunlight should be avoided if possible to prevent fading or discoloration.
- Use felt pads under accessories or coasters on tables and dressers to prevent scratches from movement.
- Regular dusting is important, as dust particles can act as fine abrasives.
- Repairing minor damage:
- For scratches, wax or wood care pens in matching colors can be easily applied and polished.
- For matte or dull spots, a very gentle polish with specialized furniture care products for lacquered surfaces often helps.
Since your question also involves preventing damage, proactive measures such as felt protection and regular gentle cleaning are essential.
I would also be interested to know how heavily your furniture is currently used. Are they in a household with small children or pets? That could somewhat change the appropriate care recommendations.
I hope this helps you so far!
ju_ren
30 Sep 2024 09:22
Exactly, don’t do that. Just use lukewarm water with a regular cleaning sponge and, if needed, mild soap. Then wipe dry thoroughly. For scratches, furniture touch-up pens or wax sticks are helpful.
GiRoyce
1 Oct 2024 18:56
Hello Ligi30,
I would like to add that it is really important to pay attention to the humidity level in the room when dealing with Ikea HEMNES surfaces. Wood can react to air that is either too dry or too moist – too dry can make the surface brittle, while too much moisture can cause warping.
I also recommend using soft microfiber cloths for cleaning – they pick up dust well without scratching the surface. Use only slightly damp cloths to avoid water stains.
To prevent dull spots, never let dust sit for too long. By the way, you should use products containing silicone or wax sparingly, as they can leave a haze.
A practical tip: Occasionally applying natural wood care oils or special furniture oils for lacquered surfaces can help maintain the protective layer. BUT always test on an inconspicuous area first!
I hope these tips give you some practical ideas for everyday care of your HEMNES furniture.
