I have a specific question regarding the KALLAX shelves from IKEA: Do the KALLAX panels become porous over time?
I have noticed that some furniture made from similar wood-based materials can become more porous and brittle on the surface over the years due to environmental factors such as humidity and temperature fluctuations. I am interested in whether this also applies to the KALLAX panels, which are made of particleboard with a foil coating.
Are there any experiences or perhaps technical details that explain whether one should expect material degradation due to porosity and associated wear with KALLAX?
Thank you very much for your insights!
Hello Bayram56,
regarding your question about whether KALLAX panels become porous over time, I can provide some information. Basically, the panels are made of particleboard and coated with a melamine resin surface or laminate. This layer serves as protection against moisture and mechanical wear.
The answer largely depends on environmental conditions. In damp rooms, particleboard can swell at the core if the laminate is damaged. This can lead to micro-damage in the material, which may feel like a type of porosity – fine cracks, crumbling spots, wear. However, the surface itself does not become porous in the true sense if the coating remains intact, but it can become brittle over time due to long-term exposure to UV light or chemical effects.
Have you been using the panels for an extended period, or are you referring to a new purchase? It would also be helpful to know if you have observed any specific stresses, such as heavy loads or moisture exposure.
Bayram56 schrieb:
Are there any experiences or perhaps technical details explaining whether one should expect material fatigue due to porosity and related wear with KALLAX?
Domau0 schrieb:
In damp rooms, chipboard can swell in the core if the laminate is damaged.This is an important point because KALLAX panels are not solid wood but rather veneered and laminated. It is crucial not to expose the panels to excessive moisture.
Personally, I have had my KALLAX furniture in the living room for about 6 years, and the panels still feel just as smooth and sturdy as when I first got them.
If you are concerned about durability, I would also recommend checking the panels regularly for small scratches or dents. Once the protective layer is damaged, moisture can penetrate and harm the material.
So, it is less a matter of material aging through normal use and more about environmental factors and maintenance.
I would like to make a critical remark here:
This is an assumption that cannot be made universally. Melamine resin layers can develop microcracks over time due to mechanical wear, temperature fluctuations, and chemical exposure. These microcracks can indeed lead to a kind of micro-porous surface, which makes the surface more susceptible to further damage.
However, the discussion lacks clear data or studies specifically on the KALLAX material. We should also differentiate between natural aging and premature material degradation.
I am interested if anyone here has long-term experience of 10 years or more, or even reports from IKEA itself based on material tests. Otherwise, it remains speculation.
Domau0 schrieb:
...however, the surface itself does not become porous in the true sense as long as the coating remains intact, but rather brittle...
BAUEVA schrieb:
...missing clear data or studies specifically about the KALLAX materialBased on my research so far: The KALLAX panels are mainly made of high-density particleboard with a melamine coating. These layers effectively protect against moisture and abrasion, as long as there is no damage.
Porous aging does not occur in these materials as long as the surface integrity remains intact.
If moisture enters through scratches or chipped coating, the core swells quickly – this can lead to breakage in a short time.
My advice: For long-lasting durability, avoid excessive moisture, protect the surface, and clean with pH-neutral cleaners. Long-term studies from IKEA are not publicly available, but many customer reports suggest a lifespan of at least 10 years under normal residential use.
If you need more technical details, I can gladly look up additional sources.
