ᐅ Do Ikea Brimnes wardrobes often have issues with additional costs after purchase?
Created on: 23 Jun 2019 08:17
mile57Hello everyone, I am considering buying an Ikea Brimnes wardrobe, but during my research, I keep coming across the term “creep issues.” My specific question for you is: Do Ikea Brimnes wardrobes often experience creep problems, meaning deformation or material fatigue after prolonged use, especially when fully loaded? I would like to know whether this is a general design flaw or more likely due to improper use. I would appreciate hearing about your experiences and professional opinions.
mile57 schrieb:
Do Ikea Brimnes cabinets often have issues with creep, meaning deformation or material fatigue after prolonged use, especially when fully loaded?From a technical perspective, Ikea Brimnes cabinets do not have inherent design flaws that typically cause creep. The carcass panels are mainly made of particleboard with a melamine coating, which makes them somewhat sensitive to excessive static load and moisture. Creep problems usually only occur if the specified load limits are significantly exceeded or if the assembly was not carried out properly. Tests and user reports confirm that stability is maintained with correct use.
I have a Brimnes wardrobe at home and haven’t had any problems so far! Very sturdy for the price and really practical. 😊 Of course, you shouldn’t overload it with too much at once, since every wardrobe will eventually give in under too much weight! 😉 But if you take care during assembly and follow the maximum weight limits, you won’t experience any sagging or warping over time. So no worries—I can confirm this from my own experience!
As an addition: Post-loading issues can also occur with affordable furniture if the assembly is not precise or if the cabinets are placed too close to damp walls. It is advisable, with Brimnes, to pay close attention to the exact fastening of the back panel and accuracy during assembly. Additionally, it is important to observe the maximum load capacity of the shelves. Overloading can lead to gradual deformations, especially with particleboard furniture. This should be taken into account when storing heavy items, such as many heavy books or attachments.
mile57 schrieb:
Do Ikea Brimnes cabinets often have issues with creep, meaning deformation or material fatigue after extended use, especially when fully loaded?From a systematic product perspective, the Brimnes cabinet is solid in terms of creep resistance but not exceptionally durable. Particleboard has inherent weaknesses when exposed to moisture and overloading, which can lead to slight deformations if used improperly. For residential use, the load capacities are adequately designed. As long as the assembly instructions are followed carefully and the cabinet is not overloaded arbitrarily, long-term damage is unlikely.
