Tanguybi5628 Dec 2020 14:23Hello everyone,
I am currently planning to upgrade my Kallax shelf from IKEA and am considering installing antique handles on the modern Kallax doors. The doors are not original but replicas, intended to make the cabinet look more homely. My specific question is: do slightly older, antique furniture handles hold reliably from a mechanical perspective on the thinner substrates of the Kallax doors? I imagine that the mounting holes and the stability of the doors could potentially be an issue, especially if the handles are rather heavy or large.
Does anyone have experience with how this combination performs technically and visually? Are standard screws sufficient here, or is reinforcement necessary? I look forward to tips and experiences, particularly on how you have implemented similar projects.
Best regards!
Best regards!
Matthewt4828 Dec 2020 15:07Tanguybi56 schrieb:
Does an older, antique furniture handle hold reliably on the thinner surfaces of Kallax doors at all?Hello!
That’s a very good and valid question. Kallax doors are indeed quite thin (usually about 12 mm (0.5 inches) thick), which means that when mounting heavy or large handles, the material can quickly reach its load limits. Antique handles often have special screw spacing and thicknesses that differ from modern standard fittings.
From my experience and that of friends: besides using appropriate, longer screws, it’s worthwhile to add reinforcement. For example, you can glue a small wooden board or a thin MDF panel on the inside of the door to strengthen it, then screw into that. This helps distribute the load better.
Many also check whether the screws have good grip and may order suitable threaded rods or anchors if needed. If you want the handles to match well visually, it’s also a good idea to measure them beforehand and consider their weight.
With lightweight antique handles, it usually works well; with heavier ones, reinforcement is definitely recommended.
I hope this helps you!
Matthewt48 schrieb:
It’s worthwhile, besides using the usual appropriate long screws, to also install a backing reinforcement.Exactly. Usually, it doesn’t work without additional reinforcement.
The Kallax doors are thin and fragile. If you want to install antique handles, add a reinforcement or use different screws and washers accordingly. That will hold.
Tanguybi56 schrieb:
Are regular screws sufficient here, or do you need to use reinforcements?Hi! Years ago, I had the experience of fitting my IKEA cabinet with old brass handles. Without reinforcement, it was a bit of a gravity experiment 😉 – the handles held for a few weeks, then they gradually started to loosen.
My advice: screws are fine, but use longer and thicker ones, and especially small washers. They distribute the load better, and with antique pieces, you definitely want to avoid damaging the paint or surface.
Also, gluing a thin wooden panel inside the door really makes a difference. You don’t want to keep worrying that the cabinet will suddenly break apart. 🙂
So: it will hold if you put in a bit of care and some precise measuring!
Timofa schrieb:
I once had the pleasure years ago of fitting my IKEA cabinet with old brass handles.In addition to the visual aspect, it is important to consider the technical fit: Antique handles often have unusual drilling distances that do not match the standard dimensions of Kallax doors.
Kallax doors are usually made of MDF with a thin layer of paint; directly screwing in large or heavy handles can be problematic without reinforcement, as the screws may overload and tear out the material.
It is recommended to add reinforcement—such as an additional MDF or plywood panel behind the door—secured with suitable wood glue and small screws. This way, the tensile load of the handles is spread over a larger area.
For the screws themselves, choose appropriate lengths that pass through both the door and the reinforcement and can be fixed with nuts or insert nuts. Alternatively, blind rivets or special furniture fittings can be used from the inside.
In short, antique handles do hold well, but only with proper technical preparation and reinforcement. Without these measures, you risk damaging the material and having loose handles.
