I have a pretty specific question about the BILLY shelf from IKEA that has been on my mind for a while: Is it actually possible to make or recreate replacement parts for the BILLY shelf yourself, for example if a side panel, a damaged shelf board, or the back panel are no longer available or only very difficult to get as original spare parts?
I’m not just talking about simple repairs with wood glue or screws, but a complete DIY approach to making matching replacement parts that are reasonably stable in quality and can be installed without problems later on.
Has anyone here had experience with this? Which materials would you recommend, and what would be the best way to accurately take measurements and replicate the fastenings? Or is it better to just buy a new shelf or maybe solve it with external panels from a hardware store and special dowel/screw systems?
I’m looking forward to your tips or experiences – also happy to hear about potential pitfalls. Thanks in advance!
Yes, making spare parts yourself is possible if you measure precisely and use the appropriate wood or MDF. It is especially important to replicate the exact fastening points 1:1.
Simply work with a jigsaw and drill, plus dowels and wood glue.
Original screws can often be ordered separately as well.
Hello tupéo36,
I would divide building your own replacement parts into two main areas:
1. Material Selection and Cutting
- BILLY parts are usually made from white-coated particleboard (16 mm) (5/8 inch), MDF 18 mm (3/4 inch) is often a better alternative because it is more stable and easier to work with.
- Measure dimensions exactly using a digital caliper or tape measure, and double-check multiple times!
2. Fastening and Assembly
- Use so-called "Minifix" connectors or 5 mm (3/16 inch) dowels, as the BILLY shelf uses typical wood joiners.
- Match screw lengths and diameters as closely as possible to the original – IKEA offers replacement screws for purchase.
Common mistakes in DIY builds include incorrect measurements, wrong dowel types, or panels that are too thin. This can cause wobbling or poor stability.
Finally, I recommend making a test panel first to check fit and stability. This way, you can avoid costly mistakes.
If you have any specific questions about the process, I’m happy to help!
Interesting question, tupéo36, which is often underestimated. Completely DIY-making replacement parts for BILLY shelves requires careful planning and good craftsmanship. I will go into this in more detail.
First of all: The BILLY shelf design is based on standardized panel sizes and a sophisticated connector system that not only provides stability but also makes the shelf modular and easy to assemble. If you want to make a replacement part yourself, you need to pay close attention to the following points:
- Material: White-coated particleboard is almost the standard, but MDF or plywood panels with white foil coating are also affordable and easy to work with. It is important that the thickness is exact (usually around 16 mm (5/8 inch)) for the fit of dowel holes and back panels.
- Dimensional accuracy: A 3D caliper or at least a precise digital caliper is essential. The challenge is not only length and width but also drilling for dowel holes, shelf support holes, and rear grooves for the back panel.
- Tools: A router or CNC milling machine makes the work much easier but is usually not standard in home workshops. Alternatively, you will need to work a lot with handheld routers and drills.
- Fastening systems: IKEA mostly uses wooden connectors (Minifix, connector screws), which you can usually also get as spare parts either from the online shop or third-party suppliers. However, you must replicate the pre-drilled holes in the panels exactly.
- Coating/finishing: If you want the surface to be authentic white, a foil finish or spray painting is necessary. Many make the mistake of using simple linseed oil or wood lacquer systems, which appear matte or differently glossy and then visually disturb the look.
- Back panel: The thin hardboard or thin particleboard with standardized dimensions centered on the panel is important. Simply using a different panel can affect stability.
Stability can also be problematic because in BILLY shelves the back panel partly acts as bracing. If it is not original or comparable, the shelf can become unstable.
From my experience: For a single panel, the effort is worth it if you are skilled and take exact measurements. For multiple parts or if the shelf will be heavily loaded, buying replacement parts or a complete new shelf is usually more effective.
One more question for you: Do you have specific replacement parts in mind (e.g., side panel, base shelf), or is it about any parts in general? Then I can possibly provide more targeted help.
[quote=Filippo, post: f6v3j2, member: XXX]One more question for you: Are you looking for specific replacement parts (e.g., side panel, bottom board), or is it about any parts in general? That way, I might be able to help more precisely.
Thanks to everyone so far for the great information and tips!
To clarify: I’m primarily interested in the side panels and possibly the back panel. I’ve noticed that with older BILLY bookshelves, the side panels often get damaged or warped over time, and replacements are not always available. The bottom and shelves are usually easier to replace.
Another question I have: If I were to remake a side panel myself, how do I get the typical holes for the shelves and dowels in exactly the right places? Is there some kind of template or technical drawing that someone knows about, or does it really have to be measured and marked completely by hand?
I’m also curious whether you would recommend, in this case, to go for a ready-made wood shelving unit from a hardware store and plan the shelf with slightly different dimensions — or to strictly build everything matching the IKEA system.
I’m looking forward to more opinions, as I want to repair the shelf as original and stable as possible.
