ᐅ Dividing a Room After Construction
Created on: 24 Mar 2017 20:37
Nico2016
We are planning to convert the upper floor from two large bedrooms (27 and 23 m² (290 and 248 ft²)) into three. The larger room has a double casement window centered on one wall. The smaller room has three floor-to-ceiling windows, each the size of a door, also centered.
How much effort is involved in dividing one of these rooms using the existing windows? What is the best approach (e.g., drywall partition)? Is a narrow section of the window area sufficient to attach a drywall partition?
Also, how is the heating issue usually addressed, since only one of the new rooms will keep the radiator?
11ant25 Mar 2017 14:39
The door situation is already tricky.
Nico2016 schrieb:
with closed windows about 2cm (1 inch) wide where a wall could be attached.
On this sandbank, I don’t see the desire to anchor.
Nico2016 schrieb:
Correct, all the assumptions were right,
Finally, I was already accused several times here of wild speculation ;-)
25 Mar 2017 22:20
Is the house already built, or are you looking to change the floor plan for a new construction?
I assume I’m not the only one thinking the house already exists...
Regards, Yvonne
