We are planning to convert the upper floor from two large bedrooms (27 and 23 m² (290 and 248 ft²)) into three. The larger room has a double casement window centered on one wall. The smaller room has three floor-to-ceiling windows, each the size of a door, also centered.
How much effort is involved in dividing one of these rooms using the existing windows? What is the best approach (e.g., drywall partition)? Is a narrow section of the window area sufficient to attach a drywall partition?
Also, how is the heating issue usually addressed, since only one of the new rooms will keep the radiator?
Maybe a drawing of the existing layout would be useful?... and photos.
Nico2016 schrieb:
We plan to convert two large bedrooms upstairs (27 & 23 m2 (290 & 247 sq ft)) into three. The larger room has a central double casement window. The smaller room has three full-height, door-sized windows arranged centrally.I’ll try to interpret :-) that the "double casement window" refers to a combined window unit with two sashes separated by a mullion, each opening separately (so not a French casement), but probably only one of them is tilt-and-turn while the other is just turn; and that between the three full-height windows there are covered beams? Or does "a narrow post" mean it’s a single continuous unit with three mullions the width of the window frame profile?
Nico2016 schrieb:
And how do you solve the heating issue, since only one room keeps the radiator?The simplest solution would probably be to branch off a second radiator from the existing one (installing a T-piece, allowing a hose to extend to the new radiator). As for control, the second radiator can effectively be a follower; if the rooms are of similar size, it could be the same size radiator for convenience. But the heating engineer will have a more informed opinion on that than I do.
Correct, all the assumptions were right: the double casement window is one unit with two operable windows and a narrow mullion between them. When closed, this mullion is about 2cm (1 inch) wide, where a wall could be attached. The floor-to-ceiling windows have wider mullions, approximately 8cm (3 inches) wide when fully closed.
Attached is a floor plan. I’m currently unable to provide photos.
The heating situation sounds good so far.
