ᐅ Distribution Cabinet – What Size Is Practical and Recommended?
Created on: 15 May 2018 12:32
DanielaSHello everyone,
We are about to start the electrical installation work and are wondering what size distribution board we should have.
Our house is 180 sqm (1,937 sq ft), with 2 full floors, an air-to-water heat pump, underfloor heating, and a photovoltaic system with battery storage. Because of this, we probably don’t need a separate meter for the heat pump electricity.
Our electrician initially recommended a four-module distribution board, for the main house and a separate apartment (which we don’t have), the photovoltaic system, and the heat pump electricity (cost: €1,100).
Our solar installer said we only need two modules, for the house and the photovoltaic system (cost: €520). However, I’ve recently read that it’s better to plan for a larger distribution board.
I will definitely consult our electrician again but wanted to hear your thoughts on this.
Thank you very much!
I believe fields are meant here.
I would not allocate space for a second meter. The photovoltaic system runs through a bi-directional meter, and self-consumption can be measured with a small device mounted on a DIN rail. Generally, very little from the photovoltaic system actually stays in the panel.
A bit of extra space doesn’t hurt, but there’s no need to overdo it unless home automation is planned – in that case, I’d go for the largest panel ;-)
In this configuration, there would be 132 modular units (MUs). I would also consider this the absolute minimum.
About 24 MUs are used for possible cable entries and lightning protection, 12 for neutral and protective earth, leaving only 96.
Adding a residual current device (RCD) here and there, and not just the usual two circuits per room but a bit more, means there isn’t much left. It still fits, but it’s tight.
If you want it to be expandable or possibly add some home automation later, I would opt for the next larger size.
Alternatively, a cabinet with these dimensions but two energy meters instead of the outdated 3-point meter slots would gain another section with 84 MUs (if the utility company agrees). After subtracting those that would be lost, there would then be 192 MUs.
