ᐅ Distribute telephone cables at multiple locations throughout the property.
Created on: 13 Jul 2021 17:45
HausnerHello,
for example, I need to install a phone cable A-2Y(L)2Y 2x2x0.8mm² (2x2x0.003in²) to my rainwater cistern for level measurement, as well as at other locations, such as the garden gate. I want to gather the cables in the garage and then bring them into the house with an A-2Y(L)2Y 10x2x0.8mm² (10x2x0.003in²) cable.
The distance from the garage to the cistern is about 25 m (82 feet). In theory, I could run a 4x2x0.8mm² (4x2x0.003in²) cable to the cistern and from there continue to the garden gate, which is another 25 m (82 feet) away. However, I am wondering how and where I could connect the cables? Are there underground or above-ground waterproof junction boxes available?
I am installing a CAT7 cable in parallel for the hands-free system. I plan to use the telephone cable at the cistern to connect a level sensor and at the garden gate for one or two reed switches.
I have researched further and will probably install a distribution box at the top of the dome of the cistern.
nordanney13 Jul 2021 23:21Hausner schrieb:
Are there underground or above-ground waterproof junction boxes?Friedl junction boxes with couplings. They are IP 68 rated and relatively affordable.B
borderpuschl14 Jul 2021 09:31Possibly also add a coaxial cable to the cistern, so you can switch to ultrasonic measurement if your currently planned method doesn’t work. 😉
nordanney schrieb:
Friedl junction boxes. They are IP 68 rated and relatively affordable.I am also using the same ones. Unfortunately, I cut the opening on the rubber end cap too large on one of them. Does anyone have a tip on how to fix this without having to buy a new box (I couldn’t find any replacement parts anywhere)?Similar topics
