ᐅ Spacing of screws for drywall panels
Created on: 15 Feb 2014 18:26
senni-1
15 Feb 2014 18:26
Hi,
we are currently unsure about the maximum spacing allowed for screws on drywall panels.
Is there a standard for this, or can you place screws according to your own judgment?
Of course, the panels should be securely fixed, but the fewer screws used, the less filling work is needed 🙂
Thanks.
Senni
Kurt1985-1
22 Feb 2014 08:50
Hi Senni,
I can't say if there is a standard for this. It also depends on the thickness of the drywall. I always use a spacing of 20 centimeters (8 inches), and that has worked well so far.
So, enjoy your work!
nam-1
22 Feb 2014 12:51
Well, you have to use filler anyway, right, or are you leaving the joint open? And whether you close the tiny holes more when filling—no, that really isn’t an excuse.
Paule-1
22 Feb 2014 12:56
So, depending on the substructure, we always screwed at intervals—for example, every 25cm (10 inches) on stable battens, also along the entire joint. Some people screw every 15cm (6 inches), but that gets expensive because the screws themselves are the cost, not the small amount of filler 🙂
Luca-1
23 Feb 2014 08:47
I place the screws at intervals of 25 cm (10 inches), and actually, it doesn’t matter how many screws are countersunk. The small amount of filler material doesn’t cost anything.
henry-1
23 Feb 2014 09:08
Hmm, there are some guidelines...
Screwing
• The first panel is precisely leveled using a spirit level and screwed in starting from the center.
• For the following panels, the screwing begins at the adjoining corner and continues without putting tension on the panels.
• Screwing is done first on the more stable web side of the lateral CW profile flange. The point markings in the center of the visible sides and the panel backs provide good reference points for adjusting the studs at the panel center.
• A flat bearing surface at the panel joints of half the CW profile width must be maintained.
– First fastening point = approx. 100 mm (4 inches) away from the ceiling or floor (see picture 3).
• For structural reasons, it is beneficial to screw the drywall screws in a staggered pattern with a spacing of 20 to 30 mm (1 inch)
So, a 25 cm (10 inches) spacing is actually not bad; 15 cm (6 inches) starts to be overdoing it 🙂
