ᐅ Disadvantages of engineered wood veneer flooring? Apart from the inability to sand and refinish?
Created on: 18 Feb 2022 17:43
christophen
We have a newly built house and have been looking into flooring options lately. For the living room on the ground floor, we will use standard multilayer parquet. For the other four rooms, we initially considered vinyl flooring due to the high cost of parquet. Then some people recommended a "veneer floor" as well. This is basically parquet with a very thin wear layer.
Advantages: affordable, parquet appearance, warm underfoot... basically all the benefits of parquet.
Disadvantages: it cannot be sanded down.
Several people have told us that the inability to sand it is not really a disadvantage anymore, since hardly anyone sands their floors nowadays. Tastes also change, so with veneer flooring you have the “advantage” that after about 15 years—if the wear bothers you—you can replace it with something completely different. You don’t have to pay a lot upfront for parquet. In terms of price, veneer flooring from the company Kährs costs around €30/m² (about $30/sq ft), while real parquet nowadays is at least €60/m² (about $60/sq ft).
Do you have any experience with this type of flooring? We are not looking for a floor we have to live with for a lifetime. If the wear looks bad in 15 years, we can choose something else. That’s fine with us.
Thanks in advance for your experiences.
Parador has an outlet where they regularly offer clearance stock (often large enough for a whole house) for around 30€ (about 32 USD). That’s where I got mine, which was priced in the store at around 100€ (about 107 USD) per square meter (click parquet with a total thickness of 16mm (0.63 inches), including approximately 4.5mm (0.18 inches) of smoked oak wear layer or something similar). They are only open Wednesday afternoons for browsing. However, pickups can be made throughout the entire week.
Benutzer20019 Feb 2022 12:52christophen schrieb:
I’m asking for a link!You have to search yourself. Sharing links will get you banned. Just look online, and you will find what you need.Wood is wood—no matter which brand it’s from.
Benutzer20019 Feb 2022 12:53christophen schrieb:
Country-style floorboards were not particularly wide either (18-20cm (7-8 inches) wide, approximately 2m (6.5 feet) long).Country-style floorboards don’t come any larger. Then look for plank flooring (also called wide planks). However, these do have a premium price (rightfully so).Benutzer200 schrieb:
Country house floorboards don’t get any larger. Then look for lock floorboards. But they really do come at a price (rightly so)You can find those starting at €40 per square meter (about $3.70 per square foot). So still within a reasonable price range.M
Myrna_Loy19 Feb 2022 13:14SoL schrieb:
Even those are available from €40/sqm (approx. $40/sqft). So still within a reasonable price range.Yes, but only as shorter lengths. You might get a 1.60 m (5.25 ft) piece, and the rest will be pieces of about 60, 80, and 120 cm (24, 31.5, and 47 inches). Unfortunately, it doesn’t look good. “Castle floorboards” only make sense if they are room-length, and then it gets EXPENSIVE. Unfortunately, they are called castle floorboards, not townhouse middle-row floorboards.P
pagoni202019 Feb 2022 14:32.... maybe the solid oak floorboards don’t necessarily have to be oak either..... then you might be able to find something affordable there as well
