In the online planner, there is a corner base cabinet for the oven.
However, it can only be found under the countertops section.
I cannot find any measurements for it.
Does anyone know the exact side lengths of this base cabinet?
Thanks in advance
Brummsumerl
Thanks in advance
Brummsumerl
robi_aus_ffm21 May 2016 11:35Hello,
when you insert the corner base cabinet in the planner, you have the option to view the shopping list/item list.
There you will find the item number.
With this, you can use the Ikea search function to find the item along with its description and dimensions.
In your case, it is the standard base cabinet 70213569.
It’s simply the base cabinet positioned at a 45-degree angle, and the countertop is cut accordingly.
Because of the four additional side panels and cover panels, it looks like a standalone base cabinet in the picture, but you can skip these side and cover panels if there are other cabinets next to it.
robi_aus_ffm
robi_aus_ffm
