ᐅ The dimensions of the foundation slab are incorrect.
Created on: 18 Feb 2017 17:59
jamal-01
jamal-01
18 Feb 2017 17:59
Hello
Last week, our foundation slab was poured, and today I took some measurements.
The house is 10 x 9 m (33 x 30 ft). One side measures the full 9 m (30 ft), but the opposite side is 8.977 m (29 ft 5.5 in), so it is 2.3 cm (0.9 inches) shorter. Is this still within an acceptable tolerance?
Looking forward to your advice.
18 Feb 2017 18:14
Yes
Regards, Yvonne
jamal-01
18 Feb 2017 18:17
Yes? Could you please explain that to me in more detail?
18 Feb 2017 18:32
On the internet, you can comfortably use informal address.
2.3cm (0.9 inches) over 10 meters (33 feet) is within tolerance... Bricklayers are not precision craftsmen.
The construction tolerances are regulated in DIN 18202. I’m not familiar with the detailed rules, but 1% tolerance is definitely acceptable not only during the structural shell phase.
But what does acceptable mean: the bricklayer can fix it.
jamal-01
18 Feb 2017 18:33
Will the interior dimensions then be shorter on one side?
Which measurement, for example, would be out of tolerance?
jamal-01
18 Feb 2017 18:34
Not 10m (33 feet), but 9 meters (30 feet)
