ᐅ different tilt angles of solar collectors
Created on: 17 Mar 2011 12:09
solarus23
I want to install a solar system for domestic hot water and heating support at our house. Six flat-plate collectors are planned for the roof. Now, the problem is as follows:
Our house has a roof with a 30° pitch. However, due to roof windows and existing photovoltaic panels, there is only room for three collectors there. The other three are intended to be installed on the roof of an extension; the roof pitch there is 50°. The distance between the two rows of collectors would be about 3 meters (10 feet). Raising the collectors on the 30° main roof is not an option because it would shade the existing photovoltaic system.
How does the difference in tilt angle affect the system, and is it even possible to implement it this way? Or do all collectors need to have the same pitch? A friend told me it would be unfavorable to install collectors at different angles. He had read it somewhere but couldn’t explain why.
Does anyone have any insight on this?
Thanks in advance.
Gissi79
3 Apr 2011 18:55
€uro schrieb:
I would think about that once more. 😉
Best regards.
Why think twice about it? Heating support with radiators requires a higher supply temperature, which can only be reached with solar collectors in summer when it is not needed!
With underfloor heating, I operate at 30°C (86°F) and can heat using solar energy.
€uro
4 Apr 2011 00:29
Gissi79 schrieb:
...With underfloor heating, I run mine at 30°C (86°F) and can heat using solar energy.
Actually, it wasn’t about what you can do. I can also go get a roll with a 40-ton truck.
