I would like to get some opinions/facts on the following topic:
To achieve sound insulation or to prevent drafts inside a building (single-family house), it is possible to install a threshold at every door inside the house. This means that the finished floor level of the room the door opens into is about 2.5 cm (1 inch) lower. The door then rests on the threshold at the bottom, creating an (almost) airtight seal. For example: the hallway has a floor buildup of 17 cm (7 inches), while all accessible rooms into which a door opens have only a 14.5 cm (5.7 inches) floor buildup.
The question is: Is this a standard and recommended practice in new constructions nowadays, or was this mostly done in the past (1980s)? – I have seen it in a house from that period...
I am looking forward to your answers and opinions – thank you very much!
Peanuts7419 Jan 2016 14:39 🙄 So, we don’t have any issues with sound; maybe I just can’t hear as well anymore with >40 years.
Bieber081519 Jan 2016 14:50T21150 schrieb:
Doors should or can have a small gap when combined with controlled mechanical ventilation. Originally, the question was about soundproofing, where simple gaps are obviously counterproductive. To ensure air transfer even under higher soundproofing requirements, there are several options:
- Air transfer behind the door frame,
- Drop-down seals with an air transfer opening,
- Special transfer vents for wall installation.
Bieber0815 schrieb:
Originally, the question was about sound insulation, and simple gaps are naturally counterproductive. To ensure air transfer even with higher sound insulation requirements, there are several options:
- Drop-down seal with air transfer opening,
- Special air transfer valves for wall installation.Absolutely correct!
In our case—we live two people in the house—we deliberately chose to forgo these measures and went with the simple option.
Thorsten
