ᐅ Differences Between Tiles from a Home Improvement Store and a Tile Specialist Center
Created on: 30 Jul 2017 21:36
Steve_D
Hi,
there are significant price differences between buying tiles from a specialized tile supplier or from a hardware store.
We would tend to go with the hardware store since the construction specification lists 20€/m2 (20 €/sq ft).
What are the differences between them?
Best regards & thanks
cobra19821 Aug 2017 21:01I am curious to know if there are quality differences between tiles from home improvement stores and those from specialized dealers.
cobra1982 schrieb:
I am curious if there are quality differences between tiles from hardware stores and those from specialized suppliers.
Inexpensive tiles can certainly be of lower quality than expensive ones.
However, this is not necessarily related to whether they come from a hardware store or a specialized supplier. Specialized suppliers also carry cheap products, where the firing process was shorter than for higher-quality tiles, or where the edges are not cleanly cut.
Generally, the higher the price, the better the quality—whether in manufacturing, the consistency of the pattern repeat, or other features.
See also my post #10.
Quality is not an absolute concept but rather a standard that relates to the specific requirements. For example, a floor tile for an airport building needs different quality than one for your utility room. A tile exposed to frost outdoors requires different properties than one used in a consistently warm bathroom. This means that top-of-the-line products are often over-engineered for a private home. A tile priced at 20,- can be functionally just as good in quality as one costing 45,- or more, especially when the application is a house for two to four people.
In my opinion, appearance and style are more often the factors driving the price than measurable quality. Karsten
We bought wood-look tiles measuring 15 x 90 cm (6 x 35 inches) for the living and working rooms from Bauhaus back then, I think it was around 30 €/m² (3 USD/ft²). We planned for generous waste and were able to return tiles worth 300 € (about 320 USD) to Bauhaus in the end.
The tiler had no complaints either; the edges were fine, only one or two tiles were slightly warped, that was it. We are satisfied with the appearance.
The quality of wood-look tiles becomes apparent in how many different patterns are produced. For example, inexpensive tiles might have only 5 variations, while high-end ones can have 15. This is important when the wood grain texture is pronounced and distinctive. You don’t want to see the same knot every fifth tile.
However, warping is also more likely with large-format tiles.
I agree with ypg, we recently looked into wood-effect tiles as well, and with the cheap ones, the fake look is immediately obvious. The pattern repeats too often, and the texture is either missing altogether or very “tile-like.”
From experience, we’ve learned that it’s essential to see a sample layout of the desired tile in advance. Examining individual tiles doesn’t help. Apparently, manufacturers don’t provide any information about the sorting either.
