ᐅ Differences and Missing Power Cables for Ikea Inreda and Dioder
Created on: 2 Feb 2014 19:56
Bruce_Will_Es
Bruce_Will_Es
2 Feb 2014 19:56
What is the difference between the Inreda Spot, LED, silver-colored, and the DIODER multi-lighting, LED, white?
Is it possible that I need to purchase the "Ansluta" plug cables separately for each?
The spots are intended to replace my non-halogen spots (from 2004), whose transformer plugs often get very warm and pose a safety risk for me.
The same applies to the Inreda and Dioder light strips. Here, indirect lighting is planned behind the LCD TV.
Nordkäppchen
2 Feb 2014 20:17
Dioder is plug-and-play. Each set requires a separate power connection or, for example, a power strip.
With Inreda, you need the Ansluta cable, and you can connect up to 10 Inreda lighting sets together.
In addition, Inreda provides nearly three times the brightness of Dioder, with 80 lumens compared to 30 lumens.
I also have a Dioder strip. It provides a subtle illumination, nothing more. If you want to light, for example, a bookshelf and be able to read the titles or see your CD collection clearly, Inreda is the better choice.
Nordkäppchen
Bruce_Will_Es
2 Feb 2014 21:33
Thanks for the quick response! I’ll go ahead and order the complete package and see which one fits best visually.
