ᐅ Designing IKEA Metod Kitchen Units with Functional Corner Solutions
Created on: 12 Jul 2024 08:43
Maukorkut
Maukorkut
12 Jul 2024 08:43
I am currently planning my new kitchen using Ikea Metod kitchen units and facing the challenge of integrating practical corner solutions so that the kitchen is not only visually appealing but, above all, functional. I am particularly interested in ways to make the best use of typical corner cabinets to optimize storage space while ensuring comfortable access to kitchen utensils.
What solutions have you found for the corners in a Metod kitchen setup when it comes to combining drawers, hinged doors, or perhaps special corner carousels? What are your experiences with each system regarding ease of use, storage efficiency, and installation effort?
I look forward to your tips and advice, including any notes on specifics related to Ikea Metod, as much depends on the assembly kits and modular design. Thanks in advance!
PeoDaniel
12 Jul 2024 09:57
Hello Maukorkut,
I can understand that the corner solutions with Ikea Metod can sometimes be challenging. Basically, there are two main options: the corner cabinet with LeMans pull-outs and the version with a carousel (lazy Susan).
The LeMans pull-outs are elegant because they fully utilize the corner and provide easy access to everything; however, they are somewhat more complicated to install and more expensive. The carousel, on the other hand, is easier to assemble but can sometimes have the drawback that not all storage space is optimally used, especially in smaller kitchens.
I also recommend measuring the depth and the space next to the corner carefully, as some Ikea solutions require very specific dimensions. It is also important to consider the cabinet interior dimensions in relation to the countertop so that drawers do not get blocked when opened.
If you like, I can explain the differences between these options in more detail.
Domau0
12 Jul 2024 12:15
Hello Maukorkut,
I would like to provide a more detailed overview of the different corner solutions available for Ikea Metod kitchen units, as choosing the right option is really crucial for functionality and space utilization.
Corner cabinets can take up a lot of space if they are not planned well mechanically. Ikea’s standard solution – the LeMans pull-out – consists of two or three round shelves that swing outward when opened, making access easier. The advantage is better reach and especially the use of the deep corner area.
The downside: the LeMans pull-out requires careful planning because it has specific minimum dimensions. Its maximum load capacity is also not very high, which is something to consider with heavy pots. Additionally, the assembly is somewhat complex, so it’s important to carefully review Ikea’s installation instructions.
Alternatively, Ikea offers a classic corner cabinet with hinged doors and internal pull-outs, also known as a carousel. This option is more affordable and easier to assemble. However, usability in the back area is somewhat limited because the rotating mechanism cannot be fully utilized there.
Besides these two main options, there are also third-party solutions designed specifically for Ikea Metod, such as Magic Corner systems, which provide more storage space and better access. However, installing these systems can be more demanding, often requiring independent drilling and potentially affecting the stability of the kitchen units.
I would like to know the exact kitchen layout you have in mind (U-shaped, L-shaped, or straight) and roughly how much space you plan to allocate for the corner? This information helps to recommend the best corner solution. Your usage habits are also interesting: do you mainly have many pots and pans, or more pantry storage?
Best regards!
Gloriagl10
12 Jul 2024 13:29
I have installed the LeMans corner system in my Metod kitchen.
- Very practical
- Even smaller items are easily accessible
The installation took a bit of time.
I can recommend it if you have the space.
Maukorkut
13 Jul 2024 07:54
Thank you for the information so far, especially the detailed assessment from Domau0 – that is very helpful.
Regarding your questions: The kitchen is L-shaped, with one side about 2.80 m (9 feet 2 inches) long and the other just under 2 m (6 feet 7 inches). The corner is therefore quite narrow, but the goal is to create optimal storage space there for pots and smaller kitchen appliances. I prefer to store pantry items in tall cabinets.
At the moment, I am leaning toward taking a closer look at the LeMans system, as ease of access and storage capacity are my top priorities.
I would like to know:
- How durable are the LeMans pull-outs in the long term?
- Are there common issues with the hinge mechanisms or the pull-out system, especially with heavier pots?
- What kind of accessories or internal fittings do you use to best organize the storage space in the corner?
I appreciate any further detailed tips as well as advice on potential problems.
Dilen
13 Jul 2024 09:11
Hello Maukorkut,
Regarding LeMans pull-outs, I can add the following:
- The load capacity per pull-out is about 15-20 kg (33-44 lbs), which is usually sufficient for standard kitchen utensils. Be cautious with very heavy pots, as the mechanism may wear out faster.
- The mechanism uses sturdy hinges and telescopic slides that work reliably in practice, but it is advisable to occasionally clean off dirt and grease to ensure smooth operation.
- A common mistake during installation is inaccurate alignment of the pull-outs, which can cause jerky movement or even material stress.
For storage space, I recommend organizing the area with different levels:
- Taller compartments for large pots
- Smaller intermediate shelves for lids or cooking utensils
Suitable organizers, such as drawer inserts or pot lid holders from Ikea, can be very helpful since an unstructured space can quickly become cluttered. Vacuum-sealing your supplies can also help save storage space.
If your corner is really narrow, make sure to check whether the LeMans pull-out fits fully, as the depth can sometimes be tight.
Best regards and good luck with your planning!
