ᐅ Designing IKEA Metod Kitchen Units to Be Space-Efficient and Functional
Created on: 10 May 2024 08:24
biludeo
biludeo
10 May 2024 08:24
I am planning to design my new kitchen using IKEA Metod kitchen units, with a focus on creating a space-saving yet functional layout. Since the room is quite limited in size, I am interested in specific planning approaches you would recommend to make the best use of the available space without compromising functionality.
I am thinking about smart corner solutions, optimizing storage with pull-outs or internal organizers, as well as tips for choosing different cabinet types (e.g., narrow, tall, or shallow units). It would also be helpful to learn how to combine typical IKEA Metod options to create a well-designed work surface while providing enough storage.
How have you handled such challenges, and what should be taken into account during planning to achieve a kitchen that is both space-efficient and practical? Are there particular IKEA Metod products or planning options that have proven especially effective for this?
I look forward to your experiences, tips, and suggestions!
Blavin
10 May 2024 09:17
For space-saving and functional design of IKEA Metod kitchen units, it is important to clearly distinguish between the room dimensions and the individual needs.
- Corner solutions: Metod offers options such as carousel or LeMans pull-outs, which utilize corner storage space more effectively. These are more space-efficient than traditional corner cabinets with dead space.
- Storage optimization: Internal pull-outs, organizers, and the use of tall wall cabinets extending to the ceiling significantly increase storage capacity.
- Module variety: Be sure to consider the 20 cm (8 inches) wide cabinets to make use of narrow niches, and organize the layout by function (e.g., pull-outs for pantry items, wall cabinets for dishes).
Another important aspect is the thoughtful planning of work surfaces with free spaces between the cooking and washing areas. The IKEA kitchen planner is a helpful tool for adjusting modules perfectly.
Important: Pay attention to accurate measurements with tolerances, especially for corner solutions, as the fronts and carcasses need to fit together precisely.
Filippo
10 May 2024 11:42
Blavin schrieb:
Corner solutions: Metod offers, for example, carousel or LeMans pull-outs, which make corner storage more efficient.
I can only agree with that, especially the LeMans pull-outs significantly improve access to corner cabinets, which is often difficult otherwise.
If you approach the planning in a structured way, I recommend the following steps:
- Create an accurate floor plan including all wall niches and recesses.
- Measure the height up to the ceiling or any beams, as these often limit the usable space.
- Plan for tall cabinets for the oven/microwave and other appliances to keep the countertop free.
- For storage in the kitchen run: use pull-outs with adjustable inner lifters and drawer inserts, IKEA offers several systems.
- Also consider regulations regarding working heights to ensure ergonomic working conditions.
A particular challenge with Metod is often fitting corners, especially if the kitchen is planned as U-shaped or G-shaped rather than L-shaped. In these cases, custom cuts or additions may be necessary to optimize the space.
Are there details available about the kitchen area, such as dimensions or special built-ins? That would help provide better advice.
benon
10 May 2024 13:56
Basically, I recommend thinking early about the interior organization when planning IKEA Metod kitchen units. It’s not only about the outer dimensions but also how the storage space inside is divided.
- I have had the best experience with drawer inserts that can be easily customized, for example, for cutlery, pots, or pantry items.
- Tall cabinets are especially suitable for narrow spaces as they require little floor space but offer a lot of volume.
- Following the work triangle principles (placing fridge, sink, and cooktop close to each other) helps save walking distances.
- Small, flexible modules combined with doors or open shelves allow for a personalized fit to everyday needs.
One tip: Make sure to check if you are comfortable with Metod’s standard depths (40 cm (16 inches), 60 cm (24 inches)). In small apartments, kitchens are often only 40 cm (16 inches) deep, which helps avoid tight spots and unnecessary use of space.
It is also important to consider electrical and plumbing connections during planning to avoid later remodeling.
nonpra
10 May 2024 14:29
Corner solutions should always use carousel or LeMans pull-outs. This saves space and improves accessibility.
Tall cabinets instead of wide base cabinets take up less floor space but offer plenty of storage.
Work surfaces should not be too long, as this can negatively affect ergonomics.
Blavin
11 May 2024 07:38
Filippo schrieb:
Plan built-up cabinets for oven/microwave and other appliances to keep the countertop clear.
This is an important point, especially in small kitchens where keeping the countertop clear greatly improves functionality. Another aspect I would like to add is the use of internal pull-outs to better utilize storage space even in deep cabinets.
In addition, attention should be paid to doors and drawers equipped with soft-close systems, as found in Metod. This significantly increases comfort with frequent use.
Good planning also involves keeping walking routes as short as possible to avoid unnecessary back-and-forth movement, which is crucial in tight spaces.
