ᐅ Designing IKEA Metod Kitchen Units to Be Functional and Space-Efficient in Small Rooms
Created on: 31 Oct 2022 08:47
GebenHello everyone,
I am considering outfitting my small kitchen with an IKEA Metod kitchen unit but have a few challenges I would like to address specifically. My space is only about 6 square meters (65 square feet), rectangular but very narrow. It is especially important to me that the kitchen unit is not only functional but also makes the best possible use of the available area to maximize storage and workspace without making the room feel cramped.
I am interested in hearing about your experiences with Metod modules in very small kitchens. What is the best way to plan cabinets for space-saving configurations? Are there special combinations or accessories that work particularly well for optimizing corners or expanding work surfaces? How about variable solutions, such as pull-out elements or special organization systems?
It would also be great to know how to ensure a good workflow in the kitchen unit despite the limited space—not just plenty of storage but also an efficient arrangement of the sink, cooktop, and work area. I appreciate any suggestions or concrete planning ideas, as I often feel that small spaces allow less flexibility and you quickly reach your limits when planning a kitchen.
I look forward to your tips and experiences!
Hi,
for small kitchens, definitely use the narrower base cabinets (30 or 40 cm (12 or 16 inches)) from Metod. For corners, especially rotating carousels or LeMans pull-outs are suitable, as they make very efficient use of the space. Pull-out cutting boards above drawers can be planned for additional workspace. Also, pay attention to tall wall cabinets to make good use of the height.
Hello and thank you for your detailed question!
Small kitchen spaces can indeed be a tricky challenge, but Metod’s modular design offers many possibilities. The key is to clearly define your work zones: cooktop, sink, and prep area should ideally be located close to each other to minimize walking distances.
As Ingrid mentioned, you can also use narrow base cabinet modules. Another tip is to install several shallow, organized drawers instead of a deep, cluttered cabinet interior. This way, you can better arrange spices, utensils, and pots.
Regarding the corner: rotating carousels are practical but sometimes offer limited access. LeMans pull-outs are more flexible and many appreciate them because they can be fully extended. By the way, you might also consider countertop extensions that can be folded up or pulled out when needed.
Vertical organizers on the inside of wall cabinets often provide valuable storage space for small items, keeping your work surface clear.
If you like, I can also share some specific examples from my own planning.
TEOZAR schrieb:
Regarding the corner: carousel cabinets are practical but sometimes have limited access. LeMans pull-outs are more flexible and are especially appreciated because they can be fully extended.I would add that in small kitchens, it’s essential to carefully consider the workflow. You might want to make good use of a corner, but if accessing a LeMans pull-out disrupts the flow of movement—because you have to pull something out to the side—it can reduce work efficiency.
Furthermore, the choice between a carousel cabinet and a LeMans pull-out is not just about space but also about how often you use the corner. For infrequent use, a carousel can be sufficient.
INGRID34 schrieb:
Also consider tall wall cabinets to maximize vertical space.That is true—but you should also keep in mind that very tall cabinets can make a small kitchen feel even more cramped if they block sight lines. An open shelving combination might be worth considering here.
flo-Theres1 Nov 2022 07:55Good morning,
I would like to share a practical tip: In small kitchens, it is important to have good lighting along the kitchen run. Especially when upper cabinets are tall and close together, they often appear like a wall and visually limit the space.
Integrated under-cabinet lighting or LED strips beneath the upper cabinets create a bright, inviting work surface and make the space feel larger.
I also recommend choosing a light color for the countertops and preferably matte finishes for the fronts instead of glossy ones, as these show fingerprints less clearly.
Metod also offers very flexible organization systems for drawers and cabinets – you should take advantage of these to create tailored storage solutions. For example, versatile inserts for spices, cutting boards, or cleaning supplies.
The combination of good lighting, light color schemes, and smart storage management turns a small Metod kitchen run into a very functional solution.
Geben schrieb:
For me, it is especially important that the kitchen area is not only functional but also makes the best use of the available space to maximize storage and counter space without making the room feel cramped.I can completely understand how stressful this search can be. Especially in such tight kitchens, you often feel limited in your design options.
I would recommend paying attention to your personal habits during planning – how many appliances or cooking utensils you actually use regularly. Less frequently used items can be stored in boxes or in adjacent furniture outside the kitchen, so the kitchen area itself doesn’t appear overcrowded.
Sometimes it helps to mentally let go of the idea of a traditional kitchen layout and, for example, use a narrow kitchen island on casters that can be moved when needed – this adds flexibility.
I have worked this way myself in small spaces with my Metod kitchen and ended up very satisfied. The important thing is that the design fits you and you feel comfortable with the solutions.
