cybergnom9 Mar 2018 12:32Hello,
we will be covering most of our house (about 250 m² (2700 sq ft)) with design/vinyl flooring.
We talked to two professionals and, of course, received two different opinions:
One clearly recommends a floating installation with a click system.
The other strongly favors fully gluing it down.
Neither of them could really explain convincingly why “their” method is better.
So the question is: what would you recommend?
Thanks and best regards
cybergnom
cybergnom
Glueing has the advantage that sound insulation is often better. In theory, it is also easier to replace, but in practice, very few people manage to do this properly.
Thermal expansion is an important factor. With underfloor heating at high flow temperatures or direct sunlight exposure, vinyl flooring can sometimes develop waves. Therefore, the vinyl must be suitable for glueing, otherwise defects are inevitable.
Glueing is also more time-consuming and therefore more expensive.
KingSong schrieb:
I would definitely not glue vinyl flooring over underfloor heating! That causes so many problems... Vinyl expands and contracts much more than wood, and when you add sunlight in summer, a wavy floor is guaranteed!Flooring on underfloor heating should be glued down. How else would glued flooring be able to expand significantly?
