Hello everyone. In the area where we will be building, we can expect very hard water.
Has anyone here had experience with water softening systems?
Would you recommend a water softener?
Do you know of a good product (salt)?
I understand there are many dubious products in this field. We are looking for something that is proven to work, without any pseudoscience or dowsing rods, etc.
MODERATOR6 Jan 2010 23:28Hello Rebuel,
Water softening systems are recommended starting at 2.5 mmol/l and technically necessary from 3.8 mmol/l to prevent limescale buildup (at 60°C (140°F) water temperature in pipes and appliances). Common and proven effective systems include phosphate dosing units (only possible up to 3.0 mmol/l water hardness, requiring less space, cost-effective) and ion exchange systems (compact units for residential use are about the size of a washing machine).
It is best to check the local water hardness and consult local professionals about softening options.
Scholdei-129 Jan 2010 20:50placebo effect
As already mentioned, there are many systems available, some of which have a somewhat "esoteric" reputation.
If someone believes that the system meets its purpose, their perception is likely influenced accordingly. I have encountered residents in multi-family buildings where half were satisfied and the other half were not... this was in the case of a salt-based system.
Attention condominium owners! According to the district court in Uster, purchasing a water softening system is considered a luxury improvement (unanimous agreement required).
With salt-based systems, also make sure they are installed correctly, the salt is stored properly, and the salt container is well sealed; otherwise, you might get green corrosion.
Best regards, Markus Scholdei
Scholdei schrieb:
As already mentioned, there are many systems available, including some with a slightly "esoteric" approach.
If someone believes the system serves its purpose, then their perception is likely in line with that. I have encountered customers in apartment buildings where half were satisfied and the other half were not... at that time, it involved a salt-based system...
Attention co-owners!! According to the District Court of Uster, installing a water softening system is considered a luxury improvement (unanimous agreement required)...
With salt-based systems, also make sure the system is properly positioned, the salt is stored correctly, and the salt container is well sealed, otherwise you risk green corrosion...
Best regards, Markus ScholdéiHello,
I would like to review the ruling from the District Court of Uster today, which was not possible due to archiving. Could you please provide me with details such as the case number or involved parties? Thank you very much.
MODERATOR21 Mar 2012 10:19Hello Lt12,
Water softening systems are not just for convenience; as I mentioned earlier, these systems become technically necessary when water hardness reaches a certain level (from 3.8 mmol/l or approximately 30°dH).
When it comes to protecting pipes, pumps, and other components from damage caused by limescale deposits, this should be in the interest of all property owners. Typically, devices installed into the plumbing system require approval from the responsible water utility or supplier. Installation must be carried out only by a qualified, authorized installer.
Before installing a water softener, it is therefore important to determine whether it is technically necessary at all.
