ᐅ A tightly sealed, well-insulated wooden house without plastic? (Vapor barrier)
Created on: 30 Jan 2018 08:11
Specki
I am very interested in ecological construction, and I have a question.
Is it possible to build a highly insulated wooden house without a vapor barrier (plastic foil)? Has anyone here perhaps done this before?
Typically, a vapor barrier is used to prevent moisture from entering the insulation. Are there ways to avoid using one? The building should meet at least KfW40+ standards or better. Insulation would be either mineral wool, wood fiber boards, or cellulose. Definitely no polystyrene.
I look forward to your answers.
Regards,
Specki
Regards,
Specki
Alex85 schrieb:
It’s not about the overall airtightness of the building, but about the airtightness of the membrane. Even something as simple as a nail driven in incorrectly, for example, can allow moisture to reach the insulation and the wood.I believe poor workmanship is generally detrimental and is not limited to timber frame construction.
You can carry out the (initial) blower door test before the installation layer is closed, which allows you to fix any weak points.
You are of course right, but other construction methods do not have a membrane on the masonry that can be damaged, and in case of moisture issues, the defect would “only” need to be fixed and then dried out. With timber frame construction, you have a completely different issue.
So, there is a significantly higher likelihood of occurrence with quite a large impact.
I think that is worth mentioning.
Alex85 schrieb:
Timber frame construction Thanks ^^
I could have thought of that myself.
FHW6Neu schrieb:
Post-and-beam construction in Oberstadion I’ll take a look at that.
borderpuschl31 Jan 2018 07:39I would recommend talking to a carpenter near you to find out what is possible and, more importantly, what makes sense. We had a similar approach and also didn’t want to use a foil on the walls. We ended up gluing OSB boards and installed an insulation layer in front. In my opinion, this is the best solution (at least for us). You probably won’t be able to avoid using a vapor control layer, especially on the roof. But a professional can give you more information and show you the available options. Regarding airtightness, we achieved an average value of 0.63, although the tension frame wasn’t perfectly installed in the door and window sills had not yet been installed.
