ᐅ Retrofit Light Fixture Installation in Concrete Ceiling
Created on: 2 Mar 2025 21:01
tim-may
tim-may
2 Mar 2025 21:01
after a renovation, we have a room with an exposed concrete ceiling where I would like to at least install a ceiling light. Chasing into the concrete ceiling is out of the question, and applying a thick plaster layer to cover a chase seems too labor-intensive. The classic option of suspending a ceiling with drywall panels would be possible, but also quite involved just for one light. I have concerns about mold when using polystyrene or extruded polystyrene boards, since the room has two exterior walls and living space above. Apart from wooden panels, is there another solution I might be missing, other than using a surface-mounted cable conduit?
Thanks and regards,
tim-may
nordanney
2 Mar 2025 21:24
Electric wiring from the room above running down through the ceiling.
I would simply use a very slim cable duct.
wiltshire
2 Mar 2025 21:25
tim-may schrieb:
Is there any approach besides wood panels that I might be overlooking, apart from a cable duct?
Take a look at pictures from old Italian houses. There are manufacturers of switches and cables where three individually fabric-covered conductors are intricately braided into beautiful cables. Porcelain holders, which are screwed into the wall or ceiling, secure them. The idea: If you are installing visible wiring, make it a feature.
