ᐅ Choosing a Heat Pump Heating System
Created on: 9 Jan 2018 09:30
fortuneflake
fortuneflake
9 Jan 2018 09:30
we are planning a two-family house with 240 sqm (2,583 sq ft) and are considering the following heating options:
-Standard Brötje – Heat Pump System Complete package consisting of:
Air-to-water heat pump Split-K, up to 10.9 kW with 220 l (58 gallons) integrated hot water storage tank, electric heating element, 100 l (26 gallons) buffer tank, and commissioning by factory service
Heating capacity at A7/W35 (kW) 10.9
COP at A7/W35 4.2
Electrical power consumption at A7/W35 (kW) 2.57
COP according to BAFA list
A-7 / W35 2.46
A2 / W35 3.10
A10 / W35 4.45
Noise level indoor 52 dB, outdoor 65 dB
- Heat Pump Dimplex System M Comfort 12 kW Hot water storage 220 l (58 gallons)
Additional cost €950
Energy efficiency class low temperature A++
Energy efficiency class high temperature A+
Energy efficiency class hot water production / draw-off cycle A / L
Heating water flow temperature 60°C (140°F) ±2°C (3.6°F)
Operating temperature range air (heating mode) –22°C to +35°C (–8°F to 95°F)
Heating water flow rate / free pressure 1.9 m³/h (8.4 gpm) / 18000 Pa
Dimensions indoor unit (W x H x D) 600 x 1400 x 750 mm (24 x 55 x 30 inches)
Dimensions outdoor unit (W x H x D) 850 x 1230 x 600 mm (33 x 48 x 24 inches)
Weight indoor / outdoor unit 171 kg (377 lbs) / 98 kg (216 lbs)
Sound power level outdoor (normal operation/reduced) 55 dB(A) / 54 dB(A)
Sound power level indoor 45 dB(A)
Sound pressure level indoor at 1 m 34 dB(A)
Connection voltage (power supply heat pump) / fuse 3/N/PE ~ 400 V (50 Hz) / C 13 A
Connection voltage (control voltage) 1/N/PE ~ 230 V (50 Hz)
Heating capacity A7/W35 / COP 11.0 kW / 4.7
Heating capacity A2/W35 / COP 8.6 kW / 3.8
Heating capacity A-7/W35 / COP 7.0 kW / 2.9
COP according to BAFA list:
A-7 / W35 2.87
A2 / W35 3.77
A10 / W35 5.03
(Smart Grid Ready)
- Gas condensing boiler Weishaupt Thermo Condens WTC 15 AH-PEA complete package with gas condensing boiler WTC-15A, hydraulic set, mixing group NW 25, expansion tank 105 l (28 gallons), shut-off valve, switching valve, flue gas system. Solar system package F2 8550/15 consisting of energy storage WES 910 A C, 5 x flat plate collectors K 6 with gross area 12.55 sqm (135 sq ft), roof mounting, flexible pipe, pump group, solar controller, installation kit for hot water,
with solar system for hot water and heating support
Additional cost €3600 + gas connection fees
We lean towards the Dimplex heat pump because it has better performance values than the Brötje, and gas involves significantly higher additional costs.
However, the Brötje qualifies for a €1500 subsidy because it is modulating.
For the Dimplex, only €1300 (fixed speed) is available.
What is better?
Is my assessment correct, or how would you evaluate this?
Prospektseite mit Haustechnik und Heizungsoptionen wie Gas-Brennwertanlage und Solarthermie.
Nordmann
15 Jan 2018 22:26
The Brötje is extremely loud according to the data! 65 dB!
Bieber0815
16 Jan 2018 12:04
fortuneflake schrieb:
Gas too high additional costs
I suspect this is mainly due to the solar thermal system. Ask your energy consultant if it is possible to proceed without solar thermal. This might make the choice more difficult.
