ᐅ Decentralized Ventilation Systems With or Without Humidity Sensors
Created on: 24 May 2017 09:52
BenutzerPCB
BenutzerPC24 May 2017 09:52I received information from the ventilation installer working with our general contractor that if we install a ventilation system with humidity control, only a model with a maximum capacity of 60m3/h (35 cfm) can be used, whereas without humidity control, we could use one with 100m3/h (59 cfm). These numbers don’t mean much to me. Is that a lot? Or too little? With decentralized ventilation, is it even common to operate at maximum capacity, or is that maximum capacity an important factor? I actually see a system with a humidity sensor as beneficial and would be willing to accept the lower capacity. What do you think?
I agree, the humidity sensor probably only makes sense in the bathroom. In all other rooms, you want to remove not just the moisture but also the stale air.
