ᐅ Reducing Drawer Noise in Malm Furniture – How Does It Work?
Created on: 17 Oct 2020 18:26
ixonba
ixonba
17 Oct 2020 18:26
Hello everyone, I am currently looking into ways to reduce the noise from Malm dresser drawers. The standard Malm from IKEA often has the issue that the drawers slam loudly or even squeak when opened and closed, which can be quite disturbing, especially in quiet moments. I would like to know what practical methods you are aware of to effectively dampen or at least quiet these drawer noises without affecting the function or appearance of the dresser. I am interested in both technical solutions like dampers or self-adhesive materials, as well as maintenance tips for the drawer mechanism, since I suspect there are often improvements to be made there. I look forward to your experience and opinions, ideally with some background information so I can better understand the measures.
TYRELL
17 Oct 2020 18:42
Your concern is quite valid, as noise issues with Malm drawers often result from several factors working together. First of all, the standard metal drawer slide is often the main source of loud noise, especially when it runs dry or has mechanical play. To achieve quiet closing, so-called damping buffers made of silicone or rubber can be installed to absorb the impact. Sometimes lubricating the drawer slides with a dry lubricant, such as graphite powder, also helps, since oil can damage plastic parts and attract dust. However, it’s important to check first if the drawer is properly aligned, as crooked tracks cause additional friction and noise. Have you conducted a thorough inspection of your drawers yet? The plastic glides, often located on the sides or bottom, can also be replaced—these are usually available at a low cost from the manufacturer or third-party suppliers. Another question would be whether you want to reduce the noise when opening as well, or only when closing.
enrique7
17 Oct 2020 18:55
TYRELL schrieb:
First of all, the standard metal guide rail is often the main source of loud noise, especially when it runs dry or has mechanical play.
I can confirm this, but why doesn’t IKEA integrate damping material from the start? Are there really such significant cost differences or technical challenges? It seems unlikely to me that retrofitting would be necessary if good designs were in place.
Furthermore, it should be clearly defined whether we are talking only about impact dampers or about making the entire mechanism quieter, because a worn guide rail can’t simply be fixed with a silicone stopper. It would be interesting to know if there are any relevant long-term experiences with original and aftermarket dampers.
Landontau
18 Oct 2020 07:13
I have taken a systematic look at the issue and would recommend dividing the noise reduction for Malm drawers into three steps:
1. Check the condition of the drawer slide: play, dirt, and alignment. It’s worth lubricating with a precision machine oil or graphite—use only a small amount of oil to avoid attracting dust.
2. Replace or add rubber bumpers: these small buffers absorb energy when closing to prevent slamming. They are available as spare parts or as universal silicone bumpers.
3. Alternatively: apply self-adhesive felt strips or foam on the inside of the slide rails or on the back of the drawer for additional sound dampening.
For DIY enthusiasts, it makes sense to try these measures one after the other and observe how the sound changes. Small details like slight readjustments of the drawer are often underestimated.
Also: the sound is influenced by the contact surface between the drawer and the cabinet—consider adding small felt pads here if needed!
It may sound a bit technical, but it can be done with simple tools. If anyone is interested, I’m happy to ask about suitable spare parts and sources!
Elijah42
18 Oct 2020 09:44
Here’s the simplest solution: attach Teflon or felt pads to the edges where metal meets wood. This will make the drawer run more quietly.
Additionally, install silicone bumpers as impact absorbers. Done.
nonere
18 Oct 2020 12:05
In addition to the mechanics, material properties also play a role: the Malm drawers are made of particleboard with a melamine surface, which is relatively hard and sound-reflective. This means that noises are not dampened but rather transmitted and amplified.
More effective sound dampening can be achieved by adding soft materials at critical contact points. Self-adhesive foam with a thickness of 2-3 mm (0.08-0.12 inches) absorbs sound well.
Also, make sure that the drawer slides have no bent or damaged edges. These increase mechanical friction and cause noise.
Regarding lubrication: oil-based substances are not recommended in the long term, as they attract dust and lead to increased wear.
