During our renovation, the house electrical system will be updated. The electrician who will carry out the work offered that I could do the chase cutting myself to save some costs. He would mark everything, set up the machine, and provide a brief instruction.
Most of the walls are 11.5 cm (4.5 inches) thick. Vertical chasing is not allowed there. Currently, there are also cable ducts installed. Is it still permitted to use these nowadays?
Horizontally, conduits with two conductors are installed. It would be possible to simply chase over them and install the new cables flush-mounted (such as NYM cables and network cables).
What alternatives are there for vertical chases, and what is allowed?
Jan
Jan
garfunkel28 Sep 2016 21:34Why use an NYM cable inside a conduit instead of individual wires? Then you might be able to use the existing conduit.
There probably aren’t many alternatives if it’s prohibited.
A drywall partition for just a few cables... Well, if you have space, okay, but it seems rather impractical if it’s only for two cables—especially since, in my opinion, the latter can also be replaced by Wi-Fi.
The question is, who prohibits chasing in which context. Sometimes it’s worth questioning things.
Could it be a standard that applies to new constructions? I mean, the wall is currently chased as well and it’s still standing.
What about the further wall structure? If there is a very thick plaster layer, maybe you can chase the plaster and then plaster over the conduit afterwards.
