ᐅ Cutting IKEA Imperative Wall Panels
Created on: 18 Apr 2011 17:53
trecki
trecki
18 Apr 2011 17:53
Hello dear IKEA fans, I actually have a rather simple question. Is it possible to cut the glass using a standard glass cutter? I need to shorten it a bit.
Thank you in advance for any help.
Nayla_1068
19 Apr 2011 11:26
Hej,
since the imperative panes are made of tempered glass, as far as I know, they are difficult to modify or practically impossible for a layperson to alter. This type of glass is not manufactured like regular glass panes but is produced under tension. Even the slightest damage causes it to shatter into thousands of pieces.
NfU
Na.
Z
zeitgeist
3 May 2011 16:41
I’d like to jump in here.
So, the Imperative glass can’t be cut – but how does IKEA expect the installation to work if, for example, there is only space for 2.5 glass panes in width because there’s a wall on the left and a tall cabinet on the right, which is attached flush with the wall at the back?
Any ideas?
noonebuysfore
5 Jun 2011 01:15
we had the same issue and our first idea was to go to the glazier, have the missing piece cut, and paint the back white. However, it didn’t look exactly like the original IKEA wall panels.
Additionally, since we backlit the panels, it became obvious that the glass piece painted “by hand” looked quite uneven. I just couldn’t get the white paint layer perfect.
So I thought: if there’s already a noticeable difference between the “patched” glass piece and the original IKEA wall panels, why not turn it into a feature and emphasize the difference?
Plan B: paint the glass piece with chalkboard paint. Now the piece intentionally looks very different, and you can write recipes, small notes, etc. on it...
Those were our ideas... does anyone else have other suggestions?
Nayla_1068
5 Jun 2011 10:23
:evil: I’d like to join the discussion right away.
So, the Imperativ glass can’t be cut down—how does IKEA expect it to be installed if, for example, there is only enough width for 2.5 glass panels because there’s a wall on the left and a tall Faktum cabinet on the right, which is screwed flush against the wall at the back??
Any ideas?
Move the tall cabinet away from the wall, install the glass panels behind it, then reattach the cabinet using two spacers. Done. Oh, and of course, do NOT use the rail system behind the cabinet. Either glue it with construction adhesive or use two nails as a support surface.
NfU
Cheers.
