ᐅ Criteria for a Good Wood-Burning Stove
Created on: 1 Aug 2017 07:52
MatzeGalle
MatzeGalle
1 Aug 2017 07:52
With my new house almost finished, I am now planning to get a wood stove for the winter. My questions are:
What quality features should a good wood stove have?
What should be considered? Heat output adjusted to the size of the house, etc.
Are inexpensive stoves any good?
Thank you very much!
Evolith
1 Aug 2017 12:03
It really depends on what you want to achieve with your fireplace. If you want to heat your home, you will need one with sufficient power and a somewhat larger size. If you mainly want to create a cozy atmosphere, then a basic DIY-store fireplace will suffice.
If you prefer a fireplace that doesn’t require constant cleaning down to the hinges, the cost will be higher. Looking for one that is room-air independent? Then head straight to a specialist showroom and avoid DIY stores.
toxicmolotof
1 Aug 2017 12:35
No matter what you buy, if you want to use it properly, it will most likely be too large by 99%. [emoji23]
Bau-Schmidt
1 Aug 2017 16:19
I would recommend going to a specialized retailer and getting professional advice. That’s what I did as well.
1 Aug 2017 23:25
toxicmolotow schrieb:
No matter what you buy, if you want to use it properly, it will most likely be too large in 99% of cases. [emoji23]
But that doesn’t matter for enthusiasts: if a controlled residential ventilation system is installed, the stove should be certified – this is what the certification body (BZSF) uses to decide whether it will be approved without conditions.
Regards, Yvonne
P.S. You can get room-air-independent units at hardware stores as well, but not all sizes, dimensions, and features are available there.
