ᐅ Creating Vinyl Stair Nosing Using a V-Groove Router Bit
Created on: 12 Mar 2023 18:26
mikeT123
Hello everyone
I want to install new vinyl flooring on our staircase.
A contractor said he would pre-fabricate the steps and then install them. He mentioned using a V-groove router bit to cut a matching groove into the click vinyl.
Has anyone done this or had it done before? I wasn’t familiar with this method…
mikeT123
i_b_n_a_n21 Mar 2023 07:28
I am familiar with grooves that are not only V-shaped but also rounded so that a round metal profile can fit inside for reinforcement (common in timber construction). This way, the hard surface material, which is often less than 1mm (0.04 inches) thick anyway, remains intact, with a bonded metal profile directly underneath. This should also work well as a stair edge. Surface hardness is provided by the remaining vinyl, and the metal ensures dimensional stability.
treppe9922 Jun 2023 16:42
Hello everyone!
A well-glued stair edge is very durable and long-lasting.
This video shows how the assembly adhesive is applied to the front edge of the stair and also features the aluminum profile suggested in an earlier message (for worn steps).
Video:
[MEDIA=youtube]ErRr65VEx1A[/MEDIA]
Aluminum profiles:
https://treppe99.de/Profilor-Reparaturwinkel-Profile-aus-dem-Katalog-bestellen
Regarding the wear layer: If you are more concerned, you can choose flooring with a thicker wear layer or use a PU sealer to increase the wear layer’s durability.
Flooring with 0.7 mm (0.03 inches) wear layer:
https://treppe99.de/Treppenverkleidung-aus-Gerflor-Creation-70-Klick-Vinyl
Dr. Schutz PU Sealer
https://treppe99.de/dr-schutz-pu-siegel-seidenmatt-1-liter
Our customer advisors are always here for you. Best regards
+49 (0) 33094-719-8719
X
xMisterDx
28 Jun 2023 21:56
How is a weak point supposed to develop there? Milling a 45° V-groove is basically the same as making a miter joint. The flexible wear layer bends, the substrate adjusts, then the 45° angles fit together tightly without any gap...
The image in post #2 does not show a V-groove, someone just ran a cutter through it.
