ᐅ Crack in the window frame (PVC/plastic)
Created on: 24 Aug 2020 21:41
Stefan890
we have a crack in the corner of the window frame, see picture. The installation company is willing to retouch the crack with paint or similar. According to an expert, there is a risk that the frame may crack further and that this is a thermal bridge.
Are there any opinions on this?
Corner of a white window frame with a gap at the trim, wooden floor below.
Stefan890
25 Aug 2020 16:55
Patricck schrieb:
The issue with the plaster is not your problem. That’s their problem.
The question is rather whether the situation might get worse during the replacement due to waterproofing and so on.
I wouldn’t make such a decision alone; someone knowledgeable should be involved.
Waterproofing and similar aspects are an important point. The money needed for that can certainly be well invested.
The concern is completely justified, which is why I say bring in an expert. My expectation is that the seller will involve one of his subcontractors with fewer complaints on record than the one who originally did the work here. But the second person will probably be working alone again; the seller won’t hire a separate skilled plasterer.
We only have a contract with the general contractor. They pass on all complaints that do not concern their own work directly to the subcontractor. We have no influence over the party actually performing the work.
11ant25 Aug 2020 16:58
Stefan890 schrieb:
We only have the contract with the general contractor.
I meant the window supplier – they also have subcontractors :-(
But at least with the GC as the guarantor, you have a good chance that a plasterer will also be ordered.
Winniefred25 Aug 2020 18:20
So, we also removed old frames at our place. The damage to the plaster inside was minor and was repaired quite quickly. What kind of expected damage on the outside are they referring to? The window is being removed from the inside after all.
