ᐅ Crack in the Concrete Floor Slab
Created on: 8 Aug 2022 09:47
Robin82
Robin82
8 Aug 2022 09:47
I bought a house built in 1959.
When we removed the screed from the ceiling slab between the ground floor and the first floor, a crack became visible.
It runs almost exactly along the wall below.
Is it possible to make any judgment about whether this is dangerous or not at this stage?
Robin
Construction room with cracked concrete floor, rubble pile, and red vacuum cleaner in front of radiator under the window.
Construction site with gravel pile, vacuum cleaner, bucket, and cement bag in front of raw wall.
Axolotl-neu
8 Aug 2022 11:23
Robin82 schrieb:
Is it possible to say whether this is dangerous or not at this point?
1. Only with a structural engineer.
2. If the house was built in 1959, then there probably won’t be a problem.
Choose the answer that suits you best (I’m a pragmatist and would personally go with option 2).
Robin82
8 Aug 2022 12:21
2. If the house is made of type 59, then there will probably be no problem.
Choose a suitable option (I'm pragmatic and would personally go with number 2).
I wanted to avoid just closing my eyes and pushing through. Visually it doesn’t bother me since there will be a floating floor heating installed there. But since it’s already open and visible, you might consider doing something about it. Now is the only appropriate time. I’ve already asked a structural engineer, but he said it’s not within his responsibility. A building expert would have to be called in for this.
Tassimat
8 Aug 2022 19:48
Robin82 schrieb:
This runs almost exactly along the underlying wall.
Do you have a reinforcement plan from the house documents?
Maybe the ceiling consists of two elements that meet at this crack and rest on the wall.
Robin82 schrieb:
Is it possible to say already whether this is dangerous or not?
No, someone experienced needs to inspect it on site.
Roookie
8 Aug 2022 21:02
I have seen much worse. Just have a professional take a look if you think it’s necessary. To me, it looks like the usual settlement and stress cracks. I don’t think it’s anything serious.
Reinhard84.2
9 Aug 2022 14:43
I wouldn’t have even noticed the mini thing 😉.
