ᐅ Countertop display cabinet Ikea Faktum 92 cm wide x 40 cm deep
Created on: 27 Sep 2010 12:20
NikeaHello, is there a suitable Perfekt-Deck 92 x 40 or 47 long (about 36 x 16 or 19 inches) for the Faktum horizontal wall cabinet with glass door, like the ones for the other glass display cabinets? This is regarding the light trim at the bottom matching the cabinet. Good luck, N.
Nayla_106827 Sep 2010 22:24Hello,
no, there are no matching cover panels. The reason behind this is that it’s basically just a regular wall cabinet laid on its side. If you want to cover the sides (and attach a decorative strip), you need to use a 99mm (3.9 inches) cover panel, cut it in half, and trim both pieces to a length of 46cm (18 inches), with the cut edges facing upward, then attach the decorative strip at the bottom. Done.
Na.
Na.
