immermehr22 May 2020 19:23Hello everyone,
I am considering options for the driveway to the garage and the access to the house, with alternatives such as paving, asphalt, or concrete.
What are the advantages and disadvantages regarding:
- Cost (materials, labor...)
- Drainage fees
Thank you very much for your help
- Drainage fees
You can only save on wastewater charges with eco-paving; all other options seal the surface. If you want clear information on costs, you need to get quotes. I believe concrete is the cheapest option. However, it also has to fit into the garden design. For example, consider grass pavers, that is, a green driveway.
In many municipalities, concrete or asphalt, even with infiltration, is not allowed or is a difficult issue.
Check the local requirements from the municipality.
We have also been dealing with this topic for some time.
There is also porous asphalt available, and a new version is coming onto the market. I hope to learn more in the coming weeks.
The manufacturer gave me a price indication earlier this year. It is significantly more expensive than regular asphalt and definitely more than paving.
immermehr22 May 2020 21:20Thank you for the advice. I just checked the development plan: parking spaces, courtyard areas, house entrances, garage forecourts, terraces, and footpaths must be designed so that rainwater can infiltrate the ground. It is therefore recommended to construct these surfaces using grass pavers, turf blocks, gravel turf, permeable paving, or similar materials.
