ᐅ Costs for a Central Air Conditioning System in New Construction
Created on: 27 Jul 2021 15:56
silentserS
silentser27 Jul 2021 15:56Hello everyone,
Has anyone had experience with installing a central air conditioning system?
I am planning to install a central air conditioning system for 5 rooms in a new build: 4 units on the upper floor (one per room – 72 m² (775 sq ft)) and one on the ground floor (living room with an open-plan kitchen – also 72 m² (775 sq ft)). The construction company estimated the costs at 30,000 to 35,000 EUR.
My question is whether this amount is reasonable. The construction company I am working with is not the cheapest, but 35,000 EUR still sounds quite expensive.
silentser27 Jul 2021 16:09Mycraft schrieb:
It depends on many factors. But yes, roughly like that.
As a simple multisplit system, it will most likely be somewhat cheaper. About 10,000 (approximately 10K) less.Thanks! Good to know.
I was also told that multisplit systems are significantly cheaper. However, I would prefer to avoid having several outdoor units mounted.
silentser27 Jul 2021 17:27Mycraft schrieb:
What you probably mean are single splits. In that case, you have one outdoor unit for each indoor unit.That's right, I meant single split. Thanks again.
Traumfaenger27 Jul 2021 21:16silentser schrieb:
I am planning to install a central air conditioning system for 5 rooms in a new build: 4 units upstairs (1 per room – 72 m² (773 ft²)) and one on the ground floor (living room with open-plan kitchen – also 72 m² (773 ft²)). The construction company estimated the costs at 30,000–35,000 EUR.
My question is whether this amount is reasonable. The builder I’m working with is not the cheapest, but 35,000 EUR seems quite steep. I have a quote for 4 rooms over 2 floors, multi-split system, but the indoor units are discreetly concealed within the walls, which makes it a bit more expensive. Total price about 16,000 EUR.
