ᐅ Cost Comparison: Reinforced Concrete with Exterior Insulation and Finish System (EIFS) vs. Brick or Masonry with EIFS
Created on: 24 Jul 2019 08:45
Bauherr am L
The structural engineer said that due to the window openings in our design, it would be best to construct both floors using reinforced concrete. However, this is reportedly much more expensive than other wall construction methods.
Does anyone have experience regarding the cost comparison of
- reinforced concrete plus plastered ETICS (external thermal insulation composite system)
- solid brick plus plaster
- masonry (e.g., calcium silicate blocks) plus plastered ETICS
Thank you
Thank you
Well, that’s what this seems to be about: The original poster asks in the first post about the alternative "solid brick with plaster."
That would be a Poroton brick, and of course, that is a valid alternative. A single-family house where that doesn’t work would have to be quite exceptional, but the original poster hasn’t shared the floor plans. It’s also common to incorporate reinforced concrete columns locally into the masonry if necessary.
Sorry @nichts zu schwör
but you’re just writing confusing stuff again.
The original poster isn’t reading anymore anyway, so there’s no point in replying.
nix zu schwör26 Jul 2019 15:50@Lumpi_LE
That would be a Poroton block, which is certainly a viable alternative.
Just because the original poster’s assumption is 99% wrong.
Why would a structural engineer specify reinforced concrete or calcium silicate bricks,
if standard masonry would be sufficient?
Maybe the load-bearing capacity and bending moment from the OP’s structural analysis will be posted,
then you'll know for sure.
Bauherr am L schrieb:
The structural engineer said about our design that, due to the window openings, it would probably be best to build both floors using reinforced concrete.1) So the structural engineer hasn’t completed the structural calculations yet. 2) He doesn’t mention anything about sand-lime brick.
3) “Probably best with reinforced concrete” does not mean he considers there is no alternative.
4) For a structural engineer, reinforced concrete is always the safest choice because it requires less consideration.
5) There is a possibility that the structural engineer lacks expertise.
6) But none of this is relevant to the original poster’s question, who wanted to know about costs—and as he himself states, reinforced concrete is the most expensive option.
nix zu schwör26 Jul 2019 16:051) It doesn’t matter, since the structural engineer won’t be an idiot. We don’t know what is meant by “design,” but often a design suitable for a building permit / planning permission is meant.
2) Just another incorrect claim from you.
3) There is always an alternative, which may not be obvious to you as a layperson. I even suspect that calcium silicate brick has already been mentioned as an alternative.
4) Just another false statement from you as a layperson.
5) Here, it seems rather that you don’t have any expertise...
6) Good that you have now understood the question as well.
To be honest, as a builder, I would interpret the structural engineer’s comment as a suggestion to check whether the window openings are oversized.
nichts zu schwör schrieb:In my opinion, insulting the expertise of fellow contributors is somewhat more part of the community culture in the green forum than it is here.
2) that’s just another false claim from you
3) there is always an alternative, which as a layperson you simply don’t understand. I even suspect that sand-lime brick was already mentioned as an alternative.
4) just another false claim from you as a layperson
5) here it seems you are the one who doesn’t know much,...
nix zu schwör26 Jul 2019 16:17@11ant You don’t really believe he is a structural engineer qualified enough to question another engineer’s competence, do you?
